After searching and trial I found the below decent chinise brands and the chip quick where for me is the best. One major thing I don't like with chinese brands in solder balls is that I buy now a brand where it is decent and I learn to work with it and tomorrow this brand maybe will not exist and also the specs of the solder balls is not something non questionable.Brand: CHIPQUIK - Very GoodSn63/Pb37 Solder Spheres for BGAshttps://www.chipquik.com/datasheets/SMD2150-25000.pdf"Brand": Qwin - Good250K Solder Balls 0.25mm 0.3mm 0.35mm 0.4mm 0.45mm 0.5mm 0.6mm 0.76mm Leaded Soldering Balls Set For BGA Reballing Stencilshttps://vi.aliexpress.com/item/1005006081989767.html?gatewayAdapt=glo2vnm"Brand": PMTC - Good 250K Welding Balls Tin Beads PMTC Particles 0.2 0.3 0.4 0.45 0.5 0.6 0.76mm For BGA Weld Reworking Reballing Free Shippinghttps://vi.aliexpress.com/item/1005006081989767.html?gatewayAdapt=glo2vnm"Brand": BEST - DecentBEST 505 Size 0.2mm-0.65mm Bga Solder Soldering Ball For Tablet iPad iPhone Balls For Micro Welding Mobile Phone Repair Toolshttps://vi.aliexpress.com/item/1005001489622094.html?gatewayAdapt=glo2vnm
