Author Topic: BGA Solder Balls - Brands  (Read 1255 times)
Offline 2XTopic starter
  • Country: gr
« on: June 13, 2024, 09:29:12 am »
Hello,
I am searching on the internet to buy BGA Solder Balls but I found mostly taiwan and chinese brands. Do you know if there is any trusted brand like Stannol or Kester (I would like to buy balls with eutectic solder Sn63pb37).
  • Country: gr
Re: BGA Solder Balls - Brands
« Reply #1 on: June 23, 2024, 08:51:43 pm »
After searching and trial I found the below decent chinise brands and the chip quick where for me is the best.
One major thing I don't like with chinese brands in solder balls is that I buy now a brand where it is decent and I learn to work with it and tomorrow this brand maybe will not exist and also the specs of the solder balls is not something non questionable.
Brand: CHIPQUIK - Very Good
Sn63/Pb37 Solder Spheres for BGAs
https://www.chipquik.com/datasheets/SMD2150-25000.pdf
"Brand": Qwin - Good
250K Solder Balls 0.25mm 0.3mm 0.35mm 0.4mm 0.45mm 0.5mm 0.6mm 0.76mm Leaded Soldering Balls Set For BGA Reballing Stencils
https://vi.aliexpress.com/item/1005006081989767.html?gatewayAdapt=glo2vnm
"Brand": PMTC - Good
250K Welding Balls Tin Beads PMTC Particles 0.2 0.3 0.4 0.45 0.5 0.6 0.76mm For BGA Weld Reworking Reballing Free Shipping
"Brand": BEST - Decent
BEST 505 Size 0.2mm-0.65mm Bga Solder Soldering Ball For Tablet iPad iPhone Balls For Micro Welding Mobile Phone Repair Tools
https://vi.aliexpress.com/item/1005001489622094.html?gatewayAdapt=glo2vnm
The following users thanked this post: tooki, pope
Offline pope
« Reply #2 on: June 25, 2024, 09:07:45 pm »
Thank you for sharing your findings!
The following users thanked this post: 2X
