Author Topic: Gossen METRAHIT 2A  (Read 5116 times)
Offline kcsTopic starter
Gossen METRAHIT 2A
« on: May 21, 2012, 04:07:06 pm »
I miss Dave's DMM reviews, so I have decided to do my own review of Gossen METRAHIT 2A multimeter. Actually it is not a proper review, but...
I have bought it from eBay, it is used but looks like new. This multimeter isn't cheap. I am very happy with it, I like its built quality, the only thing that is not right is that when I adjust its ohm range for 10x, 100x or 1000x and then switch to 1x, I need to readjust it (look at the second set of photos). Comparision was made with Fluke 87 V. Everything seems all right except VAC.
« Last Edit: May 28, 2012, 02:02:44 pm by kcs »
Re: Gossen METRAHIT 2A
« Reply #1 on: May 28, 2012, 12:14:12 pm »
I want to fix this issue with ohms range. I suspect that one or some resistors could be out of range and that they need to be replaced. Is it possible to get schematics for this meter anywhere? I was out of luck trying to find it on the internet.
Offline grenert
« Reply #2 on: May 28, 2012, 01:08:19 pm »
Do you mean that you have to zero the meter each time you change ohms range?  If so, that is normal for an analog meter.
Offline Bored@Work
« Reply #3 on: May 28, 2012, 01:11:53 pm »
While I also think there is nothing to fix you could ask Gossen for a schematic. They do help people out, even with older models, if they have the information and if it isn't proprietary information.
« Reply #4 on: May 28, 2012, 01:28:07 pm »
Yes, exactly. It is strange that you say it is normal, as my old cheap Sanwa multimeters have not had that problem.
Offline Fox
  • Electronics Engineer
« Reply #5 on: May 28, 2012, 01:38:34 pm »
For Ohms measurement in the user manual Gossen says:
- choose your settings x1..x1000
- short the leads
- adjust the scale too fullscale
- measure your resistance
So with this meter you practically have to adjust your meter every time you change ranges.
If you don't have a user manual here is the link to the english one:
http://www.gossenmetrawatt.com/english/produkte/metrahit2a.htm
About the AC Volts.
The Metrahit is a averaging Meter, the Fluke has True RMS capability, maybe that's the reason for the discrepancy.
But 28V difference seems a bit much, assuming you measureing mains.
A closed Switch should have zero Ohms or less!
Offline grenert
« Reply #6 on: May 28, 2012, 01:41:42 pm »
About the AC Volts.
Fox, I think you're reading off the wrong scale.
Offline Fox
« Reply #7 on: May 28, 2012, 01:50:16 pm »
About the AC Volts.
Indeed i did  ::), not used to read analog meters any more
« Reply #8 on: May 28, 2012, 02:04:49 pm »
Thank you all.
1. Ohms. If it supposed to work this way, let it be, but I would prefer to make no adjustments.
2. VAC. Yeah, I have made the same mistake reading the wrong scale.
