They make good equipment, but often parts of the implementation are not so good. examples are using a 3 core mains cable to drive a 3 phase motor, using the red, white, green wires for phase feeds, but not having a protective earth connection aside from the inverter and the motor being bolted to the same chassis. As well using 0.5mm wire for this, on a 500W motor. Control equipment can be hit and miss, who has heard of an industrial voltage of 36VAC, the standards are 110VAC, 110VDC, 48VAC, 24VAC, 24VDC, and then line voltage either phase to phase or phase to neutral.
