Well, certainly there is no best one
There are budget meters, electrician meters, meters focused in hvac, automotive and so on..
Brymens usually are good bang for buck, in quality and functionality. Take a look at the eevblog ones.
For gen purpose in electronics, anengs seems to be very usable.
Vintage meters you could check the fluke 8000s, like the super common 8020, 8024 and 8060
I often suggest the fluke 17b, for friends as is usually found in the local market, with warranty, invoice and good enough probes.
Someone would say to you the 87V is the "best", os a good and reliable meter but, expensive.
Well, take a look on these suggestions
