I've noticed one thread about "Best Solder" but My question is different.
I'm doing a small research about solder alloy application in satellite electronics.
Also, I need to buy a solder for My self at home, ground level :-). For My self, I prefer Lead-free solder if not to expensive.
From My experience thin wires ie. 0.5 mm are to thin for soldering SOIC, USB connectors and similar size IC pins.
You must put lengthy piece of wire to make a solder joint. My be due to cheap solder wire, but also there was effect of not wetting enough.
I've worked with Fluitin Lead-free Solder wire (don't know exact alloy) - It was OK, it feels harder to solder and less wetting than with leaded Sn60/Pb40 solder wire (Fluitin, also).
It was some time before, so I forgot about wire dimensions and alloys. Fluitin lead-free may be 1mm thick Sn95.3/Ag4/Cu0.7 wire, but I'm not sure.
I've noticed the erosion that Sn60/Pb40 solder makes on soldering tips. I've worked with some brand name (like Fluitin or Chemtronics, but I'm not not sure which).
So first question is:
1) Does anybody know of brand which have solder wire (Sn60/Pb40) that doesn't make such erosion on solder tips?
I would prefer Lead-free solder. I noticed similar alloys - Sn95.3/Ag4/Cu0.7 and Sn95.5/Ag4/Cu0.5 and Sn95/Ag4/Cu1. The later Sn95/Ag4/Cu1 tends to be more expensive.
2) Could somebody tell about experience with those alloys? Is there any difference?
I know about solder dendrite forming/growth in vacuum and solder fatigue due to temperature cycling.
3) Which Solder alloys are preferred for vacuum applications. Especially for space applications, ie. Satellite electronics.
4) Which Solder alloys are preferred for durability due to temperature cycling?
Thanks.
