Author Topic: Discussion on Hakko 474 Desoldering Station  (Read 13495 times)
Offline Mr.B
Re: Discussion on Hakko 474 Desoldering Station
« Reply #25 on: April 15, 2017, 12:00:44 am »
- From the transformer primary wiring, yours (240 V) is different from mine (230 V), although I understand there is no "significant" difference, wonder if I can find the "correct" connection for my 220V mains. Guess time to do inductance and DCR measurements on the primary windings.
I don't think it will make a blind bit of difference. Anywhere between 220 and 240 should be fine.
- Since you're using the Hakko 816 handle, did it come as standard ? Or you purchased it separately ? If you did, what happened to the Hakko 809 handle ? Troublesome ?
It was an option at the time of ordering.
I prefer the pencil style over the gun style.
- About the pump diaphragm, looks like the membrane probably got pulled while secured or someone did it wrong ? (pointed by red arrows) I guess on next cleaning, you need to replace it as it may leak at that spot, cmiiw.
My photo is a bit misleading.
The lower corner had peeled up a little when I removed the pump head.
Smoothing it down (after I took the photo) resulted in a perfect seal once reassembled.
Looking at yours, I am not so sure about the NOS status.
It looks well used with the apparent flux damage to the diaphragm.
I may be wrong.
Offline digsys
    • DIGSYS
« Reply #26 on: April 15, 2017, 03:05:40 am »
Quote from: Mr.B
... I prefer the pencil style over the gun style ...
I've swapped 2x pencils to guns, as I found them much easier to keep clean. ie shorter throat. I might still have the pencils, if anyone wants them.
Offline BravoVTopic starter
  • +++ ATH1
« Reply #27 on: April 15, 2017, 03:13:50 am »
Quote from: Mr.B
Me please ..
  • +++ ATH1
« Reply #28 on: April 15, 2017, 03:30:44 am »
I may be wrong.
Its new, no apparent flux residues nor particles throughout the suction path, from the gun nozzle down to the pump head.
No doubt it may aged too like the plastic valve plate. Thanks for the suggestion, I bought the A1013 diaphragm replacement ready too just in case its torn. Mine was manufactured around late 90s.
Offline Mr.B
« Reply #29 on: April 15, 2017, 05:03:57 am »
In my second photo there is a label that says 2007.11 2
I suspect that is the manufacturing date.
I have had it for about 7 or 8 years, so that makes sense.
  • +++ ATH1
« Reply #30 on: April 15, 2017, 08:45:05 am »
Yes, I can see that your tubes are not yellowed at all.
Btw, since day one, have you ever replace that black square diaphragms before ?
Offline Mr.B
« Reply #31 on: April 16, 2017, 03:04:43 am »
No, never replaced those... After all, this weekend was the very first time I have done any maintenance.  :-[
When I had it apart they looked in very good condition.
I have replaced 2 Solder Catcher Springs and half a dozen Ceramic Filter Paper disks in the whole time.
Offline digsys
    • DIGSYS
« Reply #32 on: April 16, 2017, 03:27:49 am »
Yeah same here. Only changed internal filters once or twice over the years, maybe once unexpectedly in some incident :-)
  • +++ ATH1
« Reply #33 on: April 19, 2017, 11:44:39 am »
Small update, just had a time to continue to fix the pump heads with disintegrated valves.
The new valve plate, the semi transparent plastic thingies ( Hakko A1014 ) are now installed at both pump heads.
Offline floobydust
« Reply #34 on: July 15, 2017, 06:19:05 am »
I pulled a Hakko 470 out of the garbage, found the A1029 heating element is long obsolete  :'(
But you can upgrade Hakko 802 wand to 809. Basically put a newer A1313 (474) heating element in the wand, use a different pipe and packing ring.
Did it all and it's totally worth it, an excellent desoldering station.
Pace, Weller I've used I find they don't compare.
