Thanks Cory there is a sml GND pin and T- to the left I can use, but I did get confused as the Case GND (green wire) comes out the pwr board left side (of 3 pin connector) and shifts position to the front panel "centre pin" of the 3 pin connector! Hmmmmm
But the question is, T- has a sense resistor, very low ohms (.005R) so putting GND on T- would bypass this sense resistor. Many thanks and forgive if this is a stoopid question
Tip cal went perfect, also setting SLP and STBY temps and time. Its a great little unit. But as you said your "open source" would add more functionality.
Oh, my Iron has tilt shake sensor and NTC thermistor, This station kills my Hakko 936 and various other stations I have. But have to keep one older as its vac desolder capable. Got tips....yes!....need spare handles!
