My Quickoo T12-945 died after like its 5th use
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
I was soldering a grounding point to a metal plate... I was doing that for about 2 minutes at 380°C until the whole metal plate was hot enough.
However, after this heroic fight, the soldering station died. 24V is coming to the PCB from my external power supply, and I don’t see anything burned on the PCB.
What do you suggest I do now? Should I buy a new soldering iron, maybe a KSGER? Or try to repair this one (how?)?
Dead Quickoo
![](https://i.imgur.com/uv7U8u5.jpeg)
Heavy soldering which I was working on...
![](https://i.imgur.com/DzXzHPB.jpeg)
