Author Topic: ATTEN ST-990 vs ATTEN ST-1509  (Read 1770 times)
Offline DL90Topic starter
  • Country: cl
« on: March 11, 2022, 02:54:28 am »
ST-990 is newer (this model began to be sold some months ago) but ST-1509 is compatible with different tools (including hot tweezers)
ATTEN ST-990: https://es.aliexpress.com/item/1005003980886993.html
ATTEN ST-1509: https://www.aliexpress.com/item/1005003660996623.html
Which one should I buy? Or maybe there is a better option for this budget?
Offline thm_w
  • Non-expert
Re: ATTEN ST-990 vs ATTEN ST-1509
« Reply #1 on: March 11, 2022, 09:59:33 pm »
Interesting the ST-990 looks a bit like a Pace tip.
The 1509 is TRS.
Unless you need the tweezer option, I would get an Aixun or a T12 clone with lots of tips.
  • Country: cl
« Reply #2 on: March 12, 2022, 03:45:07 am »
What does TRS mean?
I thought these ATTEN stations were better than a T12 clone, even better than an AIXUN
is AIXUN trustworthy? I've read a lot of issues in its topic
Offline thm_w
  • Non-expert
« Reply #3 on: March 14, 2022, 09:41:36 pm »
Tip ring sleeve.
Low current connectors intended for audio use.
Atten will be more trustworthy than aixun sure, but, if you want that then buy a JBC or other major brand instead.
