Author Topic: Atten ADS1062CAL 60Mhz Digital Storage Oscilloscope 7" Wide Screen LCD  (Read 9227 times)
Offline jensTopic starter
Hours
Cooling: fan forced cooling
Humidity
Work: 85% RH, 40 ?, 24 Hours
Does not work: 85% RH, 65 ?, 24 Hours
Height
Work: 3000 m
Does not work: 15,266 m
Mechanical Specifications
Size: 339mm * Width 110.5mm * 148.5mm high
Weight: about 2.4kg
Color TFT LCD display, waveform display is more clear and stable;
Extensive trigger functions: edge, pulse, video, slope, alternate;
Unique digital filter and waveform recorder;
 Pass / Fail function;
• 32 automatic measurements;
• 2 set of reference waveforms, 20 groups of common waveforms, 20 groups of settings within the store / recall; support waveform, set, CSV and bitmap files U disk external storage and recall;
Manual, tracking, automatic cursor measurement function;
Channel waveform and FFT waveforms at the same time split-screen display;
Analog channel waveform mesh screen brightness and brightness adjustable;
Pop-up menu display mode, the user operation more flexible, natural;
Rich interface display style: classic, modern, traditional, simple;
Multilingual interface display, the English online help system;
Standard interface: USB Host: Support U disk U disk storage and a system through software upgrades; USB Device: support for PictBridge direct printing and PC connection with the remote control; RS-232.
« Last Edit: June 09, 2011, 02:22:32 am by jens »
Offline Nermash
Re: Atten ADS1062CAL 60Mhz Digital Storage Oscilloscope 7" Wide Screen LCD
« Reply #1 on: January 10, 2011, 10:50:14 am »
So, it only works between 3000 and 15266 m of altitude? Or you have to be specifically at 3000 m to take measurrement:)
Offline PeterG
« Reply #2 on: January 10, 2011, 12:37:20 pm »
I dont have a lot of work at 3000m+ altitude. As for the price ,it probably cost more for its high altitude spec  :P
Testing one two three...
Offline kedwards22
I bought one of these a few weeks ago and for the price, it's not bad. It does have a few software glitches and a very annoying lack of any accelerating scroll function (the vertical adjust has a wide range, but requires hundreds of turns of the knob to get there). Does anyone know if there is a software hack to up the bandwidth?
Offline saturation
  • Doveryai, no proveryai
    • NIST
Have you tested its basic measurement functions, its bandwidth?  linearity?  noise?  Right now those are more important features are unknown to most of us, than ergonomics.
Best Wishes,
 Saturation
Offline slburris
Do you feel up to opening it up and taking some photos of the insides?
Scott
