So I bought one of these for my Creality3D CR-10S printer, received it on Friday and now have given it a good checkout.
https://www.aliexpress.com/item/310x310x4mm-400Deg-Upgrade-Ultrabase-3D-Printer-Self-adhesive-Build-Surface-Glass-plate-for-Creality-CR-10/32921860665.html?spm=a2g0s.9042311.0.0.599b4c4dDZqG9FIt also looks like the same product can be had from Banggood (CN warehouse), for about the same shipped:
https://www.banggood.com/Ultrabase-3103103mm-Glass-Plate-Platform-Heated-Bed-Build-Surface-for-3D-Printer-p-1355618.html?akmClientCountry=America&cur_warehouse=CNThis looks like exactly the same product. Like most things I've received shipped from China it comes wrapped in plastic, in a box hermetically taped shut, with wrap, and tape tape tape. There are no instructions. There's not much to it, except it requires an elevated bed temperature to grip. The hotter, the harder it grips. As the bed cools the bed releases the print.
Short story: works great!The bed on the photos has "Creality" branding; the one I received has no branding at all. It's just a plain black pattern on a sheet of glass. (Or maybe acrylic; it's hard to tell.)
I installed it with paper clips, but will probably glue it down. I didn't know how durable it would be, or if anything would ever need scraping... It doesn't, which means it's not going to get scraped up as I'm sure the surface screen would seriously disagree with being scraped.
Updated the PLA bed temp to 65˚C. FLIR gun says 63˚C, so as usual mine underheats by about 2˚.
Preheated it and leveled the four corners, then did a 25pt mesh leveling. Only had to do this once.
Sliced and printed calibration cubes and few other quick simple items at 65˚ bed and 185˚ filament, using Hatchbox 1.75mm PLA.
All printed perfectly. Adhesion is good, not as strong as hairspray on glass, but that's a good thing as some prints can be difficult to remove. This has just the right amount of adhesion at 60-65˚. At a little over 40˚ it releases and you can just pick it up (there's a very slight tack left sometimes).
It really works very nicely! Nothing I've printed on it so far has failed to adhere. On my CR-10S with the supply voltage turned up to 13V it heats the bed from overnight cold (about 18˚) to 65˚ in four minutes. Going from a prior print at around 35˚ or so to 65˚ takes just under three minutes; many times longer than plain glass, but then for a 6-10 hours print, who cares.
It does generate quite a bit more heat and undoubtedly requires more power.
Running PLA overly hot might make it penetrate deeper and make removal harder.
