CRTs are old tech, and almost any device that used CRTs in the past now uses LCD screens instead. Anything from TVs and PC monitors, to oscilloscopes, used to use CRTs but now use LCDs instead. However, a few devices like oscilloscopes are still manufactured with CRTs (often times a scope manufacturer will manufacture both versions of the scope, selling both digital LCD scopes and analog CRT scopes, as purely analog scopes have some advantages I thing). However are these analog scopes simply using a slowly depleting supply of CRTs out of their inventory? Or are new oscilloscope CRTs still being manufactured? What about TV and monitor CRTs? While CRT monitors are no longer made, many still exist, and eventually the cathode filament in the back of the tube will burn out just like a lightbulb, meaning that to continue using such a display unit, the CRT must be replaced. Are there companies manufacturing CRTs for consumer equipment, for the sole purpose of refurbishing used video displays where the CRT's filament has burned out?
