Author Topic: Dymo 550 Thermal Printer DRM Hacking  (Read 68808 times)
Online voltsandjolts
Re: Dymo 550 Thermal Printer DRM Hacking
« Reply #150 on: June 23, 2024, 08:47:15 am »
Maybe a strange thought, but can we not find a way to flash the firmware of the older 5XL's to the new ones?
That would require the extraction of firmware from the STM32 MCU in the older 5XLs.
That's not easy because of security features in the STM32 MCU.
But it might be possible, some folks have had success in bypassing those security features, as mentioned above in reply #143
Offline ballfanta
« Reply #151 on: July 01, 2024, 11:36:08 pm »
I purchased my 5XL a while ago, my SN is QG1340XXXXXXA so obviously mine works fine with the hack. It is so disappointing to find that they seem to have actively blocked this :(.
@js_12345678_55AA any further progress on working around dymos latest effort?  I can scan my 4x6 labels.  I have another 5 rolls that i need to find at the house or i can um scan some at the local supplier. and also thanks for your efforts.
Does anybody know the sequence of the serial numbers, that we know at least which one the old hack works and for which one the new hack is needed.
Maybe for me to start
I have a 5XL bought last year which is working: QG1450022xxxA
I have a 5XL this year (bought in April) which is not working: QG2350146xxxA
I don't share the full serial number, never now who's reading it ;).
Offline BaronPils
« Reply #152 on: July 19, 2024, 07:45:34 am »
Would the following be possible
Adding bluepill firmware with multiple label-signatures on it.
Each restart of the firmware will result in a new label set.
Ideally you would only switch labelset when it is empty, but I doubt if this is feasible.
If the firmware would store like 30-50x label-ids you would still have like 6-10k labels you can print.
For a normal consumer like me this would result in 10years usage.
Offline fantasy2
« Reply #153 on: September 03, 2024, 02:10:46 pm »
If I understand correctly, even with the firmware update, as long as you have a SLIX2_TAG that has never been used before, you can still select any dymo label(match & mix), since the data is separate from the tag ID's? What happens if you use the same tag ID with different data? Does the counter still count down but then for this different label? I wonder why they haven't thought of creating a hash that would include the SLIX2 data and ID.
« Last Edit: September 03, 2024, 08:55:18 pm by fantasy2 »
Offline fantasy2
« Reply #154 on: September 06, 2024, 07:39:32 pm »
I just got a new Dymo 5XL and tore it down since people mentioned that the new 5XL does not work anymore while the old one does.
And surprise surprise, the new boards are different.
There is now a 128kbit eeprom added to the board. It's a BL24C128A.
I'm sure that's where they are storing it now and not inside the STM itself.
So.. I wonder what would happen if you keep that IC reset? I wonder if the printer would continue.
Would it make sense to read the (unencrypted?) data and figure some more out?
Also, I was looking for the IC of the 3volt power supply, but I couldn't find it yet. It's different from the normal 550. I was wondering how many amps it would allow to pull. If we could use an ESP32-C3 to be the middleman, then it would be easy to wirelessly reprogram it with different ID's. But the C3 pulls max 500mA so I was a bit hesitant to try it out.
« Last Edit: September 06, 2024, 07:42:02 pm by fantasy2 »
Offline tooki
« Reply #155 on: September 07, 2024, 09:53:34 am »
I would expect that the instantaneous current draw of the printhead and motor are at least as large as the maximum of an ESP32. (Of course, I don’t know whether the printhead and motor are powered from the 3V rail.) Could you just use a little DC-DC converter directly from the DC input in the printer?
Offline fantasy2
« Reply #156 on: September 07, 2024, 10:06:21 am »
Those are both powered from 24Volt. There is a very beefy elco for that.
Something plug and play without having to solder something to the dymo would be my preference to make it more widely accessible.
The datasheet of the CLRC663(RFID reader) says it uses 350mA while transmitting with a max of 500mA. So there is potential!
