I have it from AiXun. I've only done preliminary tests so far and put it back in the box. The review will have English subtitles and will be ready in about 2 weeks.
At first glance, the build quality is good. The handle is similar to the Quick 861DW, and the tips are interchangeable, although they differ slightly in mounting diameter.
The airflow performance appears to be not much lower than that of the Quick, despite the specifications indicating a difference (50L/min. vs 120L/min.). But I haven't measured the actual power yet.
Most of the functions are not working at the moment: Wi-Fi, soldering profiles, languages, graphs... I also don't see the calibration option. AiXun provides frequent updates, so I hope they will fix it quickly.
Currently, only temperature and airflow adjustment, 3 memory presets, and heating modes (soft/normal/top speed) along with USB-C communication are functioning. It seems like they wanted to bring it to the market very quickly.
I will also take a look inside to check the build quality. I will let you know soon.
https://youtube.com/shorts/WYsb7J7Z2Ms?feature=share
