Do you have plans to purchase a soldering stand (my assumption is a left-sided soldering stand) and a different soldering iron handle, then use them simultaneously with another type of soldering iron to ensure this? I really want to do it, but unfortunately, my finances are limited at the moment.
My plan is to use T245 and T115. I don't really see the point in T210 because I either want to solder really small SMD parts and for everything else I've been doing great with the T245. Ofc many people could make the same argument for T210 and T115 but the T210 is a bit more power limited. (but I digress)
I ordered the T420 with a T115 handle.
I also ordered a genuine JBC T115 and T245 handle, so I'll be using those two.
I did the same conversion with my Aixun T3A which is using a genuine T245 handle, and the quality of the latest Aixun handles are a lot better, but I want the "genuine" JBC experience without JBC prices and I'm doing that using the genuine hand piece and tips
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
I still have a Aixun T245 handle (from T3A), changed the connector and tested it on the T420. The problem I'm having is, it seem you have to use the stand. If you connect it via the stand, it works just fine. If you connect it via the station directly you can't turn on the iron. It is detected just fine but it is stuck in sleep mode. And before you tell me I connected it wrong, or it is the wrong handle or or or. I tested this in all possible configurations. T115 connected directly and via stand. T245 direct and via stand. Only one at a time, more than one at a time, etc. The results are identical no matter the configuration. I could no doubt make something that connects between the station and the back of the unit to allow it to turn on without a stand but what I wanted was the
T115 hanging down using those suspension hanger things and turning on and off if I take it off.
TL;DR: Yes I ordered an additional cradle so I can use T245 and T115. When I have time I want to use a single stand with both T245 and T115 with T115 hanging and T245 in the cradle.
