Author Topic: Fujitsu M2512A Magneto Optical some photos  (Read 767 times)
Offline iJoseph2Topic starter
« on: June 19, 2024, 02:44:52 pm »
Recently purchased a Fujitsu 230MB MO drive which looked a bit dirty inside.
It came in an external SCSI case which had some signs of rust around the fan .. so thought it would be a good idea to clean it up before using it.
A few dust balls inside the mechanism as well.
Re: Fujitsu M2512A Magneto Optical some photos
« Reply #1 on: June 19, 2024, 02:45:46 pm »
Dust
« Reply #2 on: June 19, 2024, 02:46:35 pm »
Dust
« Reply #3 on: June 19, 2024, 03:03:13 pm »
Does anyone know where I can find a service manual for this drive?
I searched with google as best as possible (even other drive models in case they're similar) and all I can find are user manuals.
I'm trying to take off the PCB but trying to lift it up there seems to be something on the other side holding it in place - seems to be held approx somewhere in the red marked area. (yep i did remove the two screws in the middle of the board). Hoping to get better access inside to check for any more dust and clean it up.
Thanks!
