Author Topic: Any opinions on the Aixun T420D?  (Read 77705 times)
Offline Hydrawerk
Re: Any opinions on the Aixun T420D?
« Reply #25 on: September 11, 2022, 04:27:02 pm »
Channel A and B Outputs
I do not like the (probably) high current brown flat cables.
Is the case made of plastic?
Offline Hydrawerk
« Reply #26 on: September 17, 2022, 09:54:58 pm »
Thank you for the video...
Offline Hydrawerk
« Reply #27 on: September 17, 2022, 10:01:15 pm »
Unfortunately, original JBC handles are not directly compatible with Aixun T420D.
The connector is different, but you can replace that easily.
Offline nikby
  • Country: by
« Reply #28 on: October 24, 2022, 05:29:49 pm »
Guys, if it's not too much trouble for you, check the contacts on the handle connector with a tester without installing a soldering iron.
Between which contacts is a jumper installed to determine the connected handle С115? ;)
Offline eldy
« Reply #29 on: March 21, 2023, 01:16:23 am »
Anyone know if I get shipped a 220V version of this item if I can just switch the power plug to make it work with 110V? TIA!
Offline mastershake
« Reply #30 on: March 22, 2023, 12:35:00 am »
no as far as i was told no you can not. you may be able to re wire the transformer but the 220v i was told directly by aixun uses a different transformer then the 110v ive already been through this with 2 different sellers myself. i had to get them to exchange them. if you open it up the trans may have both hookups but i dont believe it does. you can watch sdg's video where he does a tear down and shows you the transformer itself.
so i re watched the video and no its one or the other see here https://youtu.be/4dOrV8wTkaw?t=441
« Last Edit: March 22, 2023, 01:07:03 am by mastershake »
Offline mastershake
« Reply #31 on: March 22, 2023, 12:36:46 am »
there is a resistor inside the handle on both the 245 and 210 that tell the station which handle is connected so i assume the 115 is the same way i can check one tomm to see
Offline mastershake
« Reply #32 on: March 22, 2023, 03:01:32 pm »
just to double check i opened one of our 110v units and the trans in there is a 110v only. so you do need either 110v OR THE 220v
Offline eldy
« Reply #33 on: March 31, 2023, 07:25:34 am »
Thank you. A seller on AliExpress was selling a T420D with two handles and six cartridges for $220 shipped but it was only 220v. Ended up paying $320 out the door for a 110v version. Of course it had a bad 245K cartridge. Worked for 10 minutes (maybe 30 seconds soldering) and went kaput.
Offline mastershake
« Reply #34 on: April 01, 2023, 09:40:52 pm »
contact aliexpress. they should help you get a refund. they may even give you a label to send it back to the them if you ask nicely. if not contact aixun. they have been good to me. though i have 9 t420d and not a single issue with any of them. i have had to have a couple p2408s units swapped out though
Offline pcm81
« Reply #35 on: May 14, 2023, 03:06:13 pm »
Just pulled the trigger on T420D. Does anyone know if anyone makes a hot air handle compatible with this unit? Would me nice to exchange one of the irons with hot air.
Offline jbf
« Reply #36 on: May 15, 2023, 07:36:30 pm »
Short answer is no.
Hot air requires an air pump.  There's no pump in the unit so the handle would have to have a fan or pump inside it, and in-handle fans are typically trash.
They are making a hot air unit supposedly.  But as to when itll be released or what itll cost, no idea.
Offline mastershake
« Reply #37 on: May 15, 2023, 07:47:45 pm »
i can not say the info i was given was 100% correct but i was told q4 of 2023 for the hot air
Offline pcm81
« Reply #38 on: May 19, 2023, 02:32:31 pm »
Good to know. Thanks. I bought the 2-channel unit specifically with the hope that small hot air handle may come into existence... its useful to have even just for silly things like heat shrink etc; even if it is not powerful enough to de-solder an IC...
Offline pcm81
« Reply #39 on: May 19, 2023, 02:33:55 pm »
Does anyone make an adapter cable to be able to use JBC handles without rewiring?
Offline mastershake
« Reply #40 on: May 20, 2023, 08:58:53 am »
some info on the h316d the hot air station coming from aixun
https://www.aixuntech.com/newsinfo/hot-air-soldering-station/
Offline jbf
Offline mastershake
« Reply #42 on: May 28, 2023, 06:06:03 am »
that link wasnt up yet when i posted the one i did. they added it later. there is a video showing some of the features here:
Offline pcm81
« Reply #43 on: May 31, 2023, 10:47:10 pm »
T420D is in the house. So far i like it. Using a large chisel tip from JBC i was able to tin a 1/4" thick 4"x4" steel plate, so yeah enough power. The power graph is fun. Noticed that most of the time it is not running at 100%, suggesting that thermal transfer from the tip to the part being soldered is the limiting factor.
Offline mastershake
« Reply #45 on: June 04, 2023, 11:56:19 am »
way to much imo. they will come down and prob even with free shipping if given a bit of time. the actual full msrp retail price is only 187.00. i have an order in for some of the 310d's but i have no received shipping confirmation yet. im hoping i will soon though i have 12 ordered (for the shop) but the 110v versions. ill keep you all posted on when or if they ship and ill ask if maybe i can do a discount or something (i doubt it though they are stingy with discounts but i will ask) i am also asking about becoming a aixun dealer here in the usa for the people here. and stocking the products.
« Last Edit: June 04, 2023, 12:24:53 pm by mastershake »
Offline slavoy
« Reply #46 on: June 21, 2023, 05:11:40 pm »
I recently posted a full review of this station with English subtitles if anyone is interested. It is the best-made and most functional Chinese soldering station I have tested so far. I recommend it.
Offline ilkinandr92
« Reply #47 on: August 22, 2023, 08:00:19 pm »
Picked up T420 C245 for $160
Offline ilkinandr92
« Reply #48 on: September 01, 2023, 06:21:21 am »
Station arrived and tips for T245 Seem to have 2.8 ohms resistance.
Offline Ariamella
« Reply #49 on: October 09, 2023, 12:06:17 pm »
How has the T420(D) iron been treating you folk? Considering getting it over the T3A due to the T3A buzzing issues.
