Author Topic: Any opinions on the AiXun T3A?  (Read 272416 times)
0 Members and 37 Guests are viewing this topic.
Offline GnomeZA
Re: Any opinions on the AiXun T3A?
« Reply #1100 on: January 30, 2024, 09:26:29 pm »
Use atx psu. Separate 5v and 12v.
https://www.eevblog.com/forum/reviews/new-aixun-t320-any-opinions-on-it-(with-inside-pics)/msg5302402/#msg5302402
If what Gnomeza say is true, then perhaps it is possible to modify cheaper mechanic c211 which have 24v transformer and use buck converter 12v.
Both ATX PSU and a buck converter is not isolated.  They are referenced to the same supply.  Current can flow from the 12v to 24v supply and ditto for ATX supplies, it is a common hack to use 12v as your positive and 5v as your negative for a 7v supply using an ATX supply.
But actually aixun t420d use different winding for heating element. And the controller use 15v winding. (Based on Steve video)
That is what I said.  They are isolated supplies.  Meaning they are not referenced to each other.  There is no current that can flow between those two supplies.  JBC also has galvanically isolated supplies for their control and heater.
Offline GnomeZA
« Reply #1101 on: January 30, 2024, 09:32:05 pm »
Good to hear the 420D behaves ok when ground is involved.
SDG said he tested it too and found no reference such behaviour.  In another post somewhere.  So at least we have a trusted public figure saying the same thing ;)
Too bad the issues I highlighted were not public before I purchased mine - or at least I didn't find anything online when I looked. A T3A without the voltage leak and grounding issue would be a nice one.
I said this as a comment on your video also.  I would do exactly what you had done if it were my profession.  I'm a hobbyist, if I can't solder this weekend or whatever :-//
But if it is my job, I wouldn't have risked it and bought a JBC station.
I honestly think you made the right call.
Even with me or SDG or "..." saying, well I think T420D is ok.
There isn't years of testing, it has been like, what? two weeks.
That is still a huge risk for you to take.
Do you think there is a way to develop a similar station with an SMPS supply without those issues? Just curious.
I've avoided commenting on this because I think I have some ideas to get past it.
But I wanted to test it on the T3A.
My hesitation is that Aixun actually do make really decent designs, they aren't stupid.
So there must be a reason they are using these hacks to get around this, even in the T320.
Instead of say two isolated windings on the SMPS not referenced to each other or isolated DC->DC converter (for logic control or thermocouple ADC).  Leading me to think I'm overlooking something obvious.
« Last Edit: January 30, 2024, 09:34:56 pm by GnomeZA »
Offline tony359
« Reply #1102 on: January 31, 2024, 09:14:23 pm »
Well... it's a soldering station. A rod gets hot. The end. :)
What I am trying to say is that I still feel that £500 for a soldering station is too much for what it does.
You might be overestimating them :)
The following users thanked this post: CaptainBucko
Offline Duglum
« Reply #1103 on: February 01, 2024, 10:46:40 pm »
On a kinda related topic.. did anyone try the AiXun C245 tips? They are producing a small range now and not only those useless two ultra-fine plus knife tip every chinese manufacturer seems to love.
https://www.aixuntech.com/product/c245-soldering-iron-tips-/
I found them on Aliexpress for around 7,60€ including VAT (plus 3-4€ shipping) which makes them about 25% of the price and really affordable compared to the ~30€ (plus 5€ shipping) genuine JBC tips go for.
But i understand that most other 3rd party tips have been more or less crap so far.. sooo the question is, are these any better?
JCID/AiXun at least seem to really want to get a foot into this market long-term with all these stations, constant firmware updates and now tips plopping up. Wonder how the T413 will turn out.  :)
Offline tony359
« Reply #1104 on: February 03, 2024, 11:47:15 pm »
Yes.
https://www.eevblog.com/forum/reviews/why-you-dont-want-to-buy-aixun-t245-tips
The "constant firmware update" is debatable. It's a soldering station. It shouldn't need so many updates. And most of the recent ones are to hide/mitigate hardware design flaws so be careful what you wish for :)
« Last Edit: February 03, 2024, 11:49:08 pm by tony359 »
Offline GnomeZA
« Reply #1105 on: February 05, 2024, 09:53:57 pm »
The latest T420D firmware allowed me to turn off "temperature compensation" which I can only assume is the thing where they overshoot.
They also dropped the silly words like "dormancy" instead for English words people would actually deem appropriate for the situation.  Think it is "sleep" now.
There were also more configuration options around keeping the iron semi warm in the cradle and so on.
So for the T420D I think a lot of the updates are making the product better.
Covering up for hardware design problems might well be a problem for T3A at this point.
I'm not saying there are no bugs in T420D, but I think a lot of the firmware changes they made I really like, to the point that I'm not too eager to downgrade.
If only to never to see the word "dormancy" again.
Offline tony359
« Reply #1106 on: February 07, 2024, 12:09:06 am »
I'm not against updates but, again, it's a soldering iron :) It really shouldn't need so many updates. If that happens, it means they didn't a good job in the start - see the translation mistakes and a feature which allows the tip to overshoot? Why would that be something you want to enable at all? :)
It's like they somehow managed to resolve the voltage leak on the T3A but instead of just fixing it they added a menu "Voltage leak and 160C overshoot: ENABLE/DISABLE"   ;D
Anyways I see what you mean, they could just drop it and move to the next product.
Offline Paul_txl
« Reply #1107 on: February 07, 2024, 01:20:39 pm »
I ordered a T3a a while back but haven't received it yet, I've also got a JBC T254 handle and bits. Unfortunately I read this thread too late but have been following it. Has anyone tried the new software options to see if they do actually cure anything?
I was also wondering if the problems with earthed workpieces exist with the T12 or 936 handles as I will be using those?
From what I can see the T3a drives these in a more orthodox manner due to the integrated thermocouple.
Also does the latest software still discriminate (if thats not too strong) against JBC tips or has that gone away? Hopefully I can answer these myself in a few weeks when the unit turns up.
Thanks for all the info,
Paul
Offline tony359
« Reply #1108 on: February 08, 2024, 09:39:18 am »
I doubt any firmware could cure an hardware issue. An update might mitigate it at best - and apparently they also decided to go for the "hiding" option.
I'm not familiar with the T12 or 936 but I guess they all have thermocouples inside?
The problem with the T3A is that under some specific circumstances the signal coming back from the sensor becomes incorrect. The logic can only try to detect when that happens and stop pushing power into the tip like there is no tomorrow. But it won't be able to accurately control the temperature. It's like if someone covered your eyes while you're driving - you can only keep driving straight hoping there isn't a bend coming. You can get better glasses but they won't make things better when you cannot see :)
Happy to be mistaken of course! :)
Offline Paul_txl
« Reply #1109 on: February 08, 2024, 11:20:35 am »
Thanks for the info Tony, I realise you've probably committed your t3a to the dustbin now. I think there has been some investigation into the cause of this  further up this thread, but it didn't seem conclusive. AFAIK the T12/936 have thermocouples in series with the heater normally, so would be generally be driven in a similar to the T3a, although there seem to separate connections on some "936" handles. I'd be happy to use it with the workpiece on a dissipative mat or connected through a resistor to ground if that prevents the problem but its a nuisance if the board is still in the chassis.
Offline c0d3z3r0
« Reply #1110 on: March 11, 2024, 01:54:20 pm »
Updating without vendor software is now possible: https://github.com/c0d3z3r0/aixun_t3x_updater
AiXun T3A reverse engineering: https://github.com/c0d3z3r0/aixun_t3a_rev
AiXun T3x F(L)OSS update tool: https://github.com/c0d3z3r0/aixun_t3x_updater
The following users thanked this post: mebel, al777, Furna, IreuN
Offline c0d3z3r0
« Reply #1111 on: March 12, 2024, 02:01:53 pm »
... and finally we got the T3B bootloader: https://github.com/c0d3z3r0/aixun_t3a_rev/blob/master/bin/t3b_boot_v0.04.bin
Many thanks @ruslan_nesterenko
The following users thanked this post: mebel, Furna, IreuN
Offline mebel
« Reply #1112 on: May 12, 2024, 06:30:35 pm »
I have new main board for Aixun t3A, if someone is interested please contact me on PM.
Offline tony359
« Reply #1113 on: July 08, 2024, 09:52:55 pm »
Another casualty for the T3A.
Offline betoo
  • Country: br
seletor para AIXUN T3A
« Reply #1114 on: July 24, 2024, 02:53:55 am »
Bom Dia, gostaria de uma Ajuda na programação arduino para poder fazer seletor de ferramenta para 3 pontas
T12    T245   e uma Tweezers T12 ja esta funcionando mais eu gostaria de adicionar um rele para ligar automatico cooler da fumaça alguem para poder me ajudar nesta
retirou ponta T12 da base ela e selecionada e liga cooler fumaça e ao colocar o cooler fica com um delay para desligar e retirando as outras ferramenta mesmo processo.
e a ultima ponta retirada fica em stand By ..........InTe OBRIGADO,.,. :) ;)
Good morning, I would like some help with Arduino programming so I can make a tool selector for 3 tips
T12 T245 and a T12 Tweezers is already working but I would like to add a relay to automatically turn on the smoke cooler. Can someone help me with this?
I removed the T12 tip from the base, it is selected and turns on the smoke cooler and when I put the cooler in, there is a delay to turn it off and when I remove the other tools, the same process.
and the last tip removed is in standby .......... InTe THANK YOU,.,. :) ;)
nao tenho serteza que se este tradutor funciona corretamente mais vou optar por deixar as duas ja sou meio mal no portugues imagina no ingles
mais prezo uma paciencia comigo, iNTE Obrigado
I'm not sure if this translator works correctly, but I'll choose to leave both. I'm already pretty bad at Portuguese, let alone English.
But I value your patience with me. Thank you.
« Last Edit: July 25, 2024, 03:30:34 am by betoo »
The following users thanked this post: digger
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #1115 on: July 24, 2024, 05:18:34 pm »
Only post in English please.
Offline betoo
  • Country: br
« Reply #1116 on: July 24, 2024, 11:50:53 pm »
Simples detalhe de como vai ser
Simple detail of how it will be
« Last Edit: July 24, 2024, 11:52:48 pm by betoo »
Offline betoo
  • Country: br
« Reply #1117 on: July 24, 2024, 11:54:59 pm »
Simple detail of how it will be arduino cod
Offline betoo
  • Country: br
« Reply #1118 on: July 29, 2024, 04:23:39 am »
 :)  :-DD In the first tests, I'm very bad at programming, I have to enable automatic tool selection, but the Arduino code isn't helping. 8)
Offline corgon
  • Country: cz
« Reply #1119 on: August 04, 2024, 11:51:00 am »
Hey guys,
I got this station too, specifically the T3B. I liked the idea of automatic handle switching, so I came up with a simple setup.
It uses just one switching relay, a couple of optocouplers, and an 8.pin MCU. In my case, it's an el cheapo CH32V003, but it could work without it too.
All functions are preserved, including extractor detection, sleep mode, and cartridge detection. I added a feature where if both handles are removed, the system
disconnects the heater and displays "no tool."
I integrated everything into the original case on a small single-layer PCB. I took the power from the indicator LED. I also plan to add an output connector and a rocker
switch instead of the dangerous push-button power switch.
If anyone is interested in the technical details, I'd be happy to answer.
You can see how it turned out and how it works on my YouTube channel:
Offline betoo
  • Country: br
« Reply #1120 on: August 04, 2024, 06:28:04 pm »
 ^-^ Perfect  :-// I feel that I have to improve my system  :palm:  :-+
