Hi everyone,
I originally got the Aixun 3A with a 245 JBC handle, then got the T12 handle, because the tips are much cheaper. The JBC would be used for more "fiddly" work with small SMD components, while the T12 is for the "normal" through-hole prototyping.
Anyway, the in-stand detection works just fine with the JBC handle, but I can't make it go into sleep mode when using the T12 handle at all. Does the T12 handle even support in-stand detection and power-down mode? (I used the search function to look through the topic, if anyone else has mentioned that, but it seems nobody has....)
Thanks!
