This looks like a winner. Assuming it really is 200w (manufacturers have been known to overstate specs), you get better performance than the KSGER, better display, easier FW updates with USB port, sexier casing, supports 245 handle out of the box... It's a hard upgrade to the KSGER. Plus it's roughly the same price as a KSGER+245 handle+3 tips. The tips are probably garbage, but having a few junk tips on hand isn't always a bad thing. The board quality may be an issue, but most people on here should have no problem fixing a few joints. Is it possible to get the power board out too? Is it hot glued in or something?
