I've been following the threads for the Aixun, the KSGER, and the Unisolder. They all seem to be great choices. At minimum, they can all use the JBC 245 handle and tips, but with different price points, levels of involvement, and concerns. The firmware for all 3 are acceptable. Aixun has 3 firmware updates (technically 2 since the second one was broken), DavidAlfa covered the KSGER, and Unisolder is well supported also. Updating the firmware has degrees of difficulty. Aixun is the easiest. Connect it to your computer (USB C I think), download the software, find the EEVblog thread on how to navigate the Chinese menu, and you're good. The KSGER needs an ST-link, and you probably have to solder some headers to the board. The Unisolder needs a mini A, and probably a generic third party hex loader. Unisolder also costs the most. And you need a casing for it. And you might need to mount a transformer inside it. And you might enjoy it. The Aixun and KSGER are generally just plug into the wall (with some concerns about safety), but there is mini version of the KSGER too that you can use with an adapter or bench PSU. At this point, I think it just comes down to individual choice/expectations.
