Whats wrong with the Ali reviews??
I personally order 95% items from Ali(As Amezon is too expensive in my country vs Ali), and the people reviews is the 1st thing i would be looking at ali. Hack i dont even look at the store description of the item
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
and head straight to the feedback/reviews. I think if You know what u need and research it throughly there will be very less chance of something going bad.....
I dont know if posting someone's comment from Ali abt the I2c soldering station here would be approperiate or not but Here is Someone the from Aussie land And i Quote
" This I2C station is *so much* better quality than Sugon T26 or Jabe UD1200. Like a JBC station, it can use different series handles. Cool and quiet 100VA toroidal, idle power consumption <3W. Precision TC amp, Hall Effect current sensor, ESD protection on all inputs. All silicone wire, even inside the station. Even more powerful than JBC station. Software quite complete. However it isn't perfect. At 230V and above it drives C245 far beyond 130W, risks heating element burnout. At 230V+10% it will drive 180W. Unlike JBC, there is no earth current sensor to detect if tip touches powered parts. Just a few mA DC can fool TC sensor and cause temperature surge burnout. The supplied I2C tips have faulty manufacturing. Extremely high thermal resistance from heater to solder. Jabe tips work fine. The plastic isn't melt resistant."
And another one from Poland
"It is not the first cloned JBC station I've tried, but it's the best so far. It's made with quality components with "premium" feel. I love it. It supports multiple tools. tried C245, C210, C115. C245 and 115 works flawlessly out of the box. C210 had temp too low. I guess that's because CD-2E stations are not compatible with 115 and it's handled as 210. Not a problem if you're not planning to interchange 210 and 115, because it's possible to recalibrate controller. There is a toroidal transformer inside with separate winding for 12 and 24V, so there is no SMPS noise nor wandering AC voltage on DC output. Tip is properly earthed. Stand sleep function works well. It also detects contact with tip changer and turns heating off. The only reason to complain so far is that there is metal shielding inside tip changer but only on the bottom, not on the walls. And it's angled. So when disconnected hot tip falls on it, it slides and starts to melt plastic case. Easily fixable though."
Seems like they are pretty heppy with it....
