Author Topic: Any opinions on the AiXun T3A?  (Read 264930 times)
Offline c0d3z3r0
Re: Any opinions on the AiXun T3A?
« Reply #1050 on: October 21, 2023, 06:02:49 pm »
That's not related to the tips but probably that ADC GPIO failed. Check the thread for that problem
AiXun T3A reverse engineering: https://github.com/c0d3z3r0/aixun_t3a_rev
AiXun T3x F(L)OSS update tool: https://github.com/c0d3z3r0/aixun_t3x_updater
Offline Dracarris
« Reply #1051 on: October 21, 2023, 08:01:42 pm »
Hm, I see. So I'd have to change the MCU (somehow reprogram it over JTAG/SWIO?) and then implement the protection changes you presentend in https://www.eevblog.com/forum/reviews/any-opinions-on-the-aixun-t3a/msg4412704/?topicseen#msg4412704?
Edit: Can confirm that standby still works with both JBC and Aixun tips - if I connect the outermost shell (basically all the metal up until the tip) with the standby input. However, connecting the metal ring at the holder which makes contact with the stand does nothing. How??
Out of curiosity: What the heck does the "Shake" input do? This thing detects if I shake it?
Curiosity 2: Why do you need to switch the station off before connecting the USB port to a computer? Do they somehow force a voltage between PE/Neutral and the GND net? This would mean the station isn't isolated from mains at all? No transformer whatsoever?
« Last Edit: October 21, 2023, 08:45:06 pm by Dracarris »
Offline c0d3z3r0
« Reply #1052 on: October 21, 2023, 09:08:31 pm »
Oh, lucky you! Then it's NOT the ADC problem. Just to be sure, it doesn't work if it's in the stand but it does work if you directly connect the standby input on the unit with the outer shell, right?
Then you have that problem, where the connection in the cradle is loose. I think there was a post from dreamcat4 on that issue. You need to open the stand and fix that connection.
It's a option for handles without that standby detection via the outer connector. It works with a shake sensor in the handle, detecting if it's being used or not.
In early versions there was no diode (D8) protecting the USB VCC from the +24V. (added in v1.1 IIRC)
Thus, you need to turn off the supply.
The following users thanked this post: Dracarris
Offline Dracarris
« Reply #1053 on: October 21, 2023, 10:37:27 pm »
I think I narrowed down my problem: I took the standby (PORT1) wire and directly held it to the tip -> standby. Then pressed it against the metal ring at the end of the handpiece, which makes contact with the stand and where the tip inserts -> No reaction.
Looked at it, thought: Hold on, when I insert the tip, these two metal bodies should make contact, thus it shouldn't matter which part connects..? Right, if I bend the inserted tip ever so slightly, it does put the unit into standby. So, there is actually a tiny circular gap between my tips and the handpiece which keeps them from making contact.. How the heck did that happen and how the heck do I fix it?
Regarding the stand: In my version of the T3A, the stand is simply a solid piece of metal with a round plug in the back for the standby wire, so when that is plugged in, the whole stand is connected. Also tried it with the stand connected, put the iron in the stand -> No reaction. Bend the tip a bit -> into standby it goes.. JFC
Thanks for all your help!
Offline floobydust
« Reply #1054 on: October 22, 2023, 02:36:56 am »
I don't like how there is conflicting information about what the pinout of the C245 cartridge is. [...]
See also Jaume Benet Canals, President and CEO of JBC Tools his patent EP1086772A2
The following users thanked this post: c0d3z3r0
Offline c0d3z3r0
« Reply #1055 on: October 22, 2023, 09:56:54 am »
Oops, ok, third try ;) Try cleaning the tips and the handles metal ring with IPA. If that doesn't help, you might need to get a new handle :(
Offline ndarjo21
  • Country: id
Offline c0d3z3r0
« Reply #1057 on: October 22, 2023, 08:02:12 pm »
Yes, but only these three types... https://www.aixuntech.com/product/c245-soldering-iron-tips-/
Now they cloned all (?) of them \o/ That could be the reason for their recent weird change in T3A firmware v1.34, breaking (proper) support for genuine JBC tips  :palm:
« Last Edit: October 22, 2023, 08:05:10 pm by c0d3z3r0 »
Offline ndarjo21
  • Country: id
« Reply #1058 on: October 22, 2023, 10:28:11 pm »
It seems aixun also clone the c115 and c210 cartridge. But why we havent hear anything from user of T3B? Perhaps they not update the firmware?
Offline Dracarris
« Reply #1059 on: October 24, 2023, 07:36:02 am »
What does that exactly mean? And is there a way to use the latest firmware before the one that broke stuff?
Offline c0d3z3r0
« Reply #1060 on: October 29, 2023, 01:37:58 pm »
Well, a few pages back jumping temperature and massive overshoot was reported.
Initial post:
https://www.eevblog.com/forum/reviews/any-opinions-on-the-aixun-t3a/msg4971133/#msg4971133
There was a response from Aixun saying that everything is fine (with their tips?)
This and following posts: https://www.eevblog.com/forum/reviews/any-opinions-on-the-aixun-t3a/msg5058061/#msg5058061
« Last Edit: October 29, 2023, 01:45:38 pm by c0d3z3r0 »
Offline DarkKing202
« Reply #1061 on: November 02, 2023, 02:02:55 am »
Hopefully, the folks who made all the mod contributions are still here. Looking to get a finalized item list for things to check/do on the Aixun when I get it.
Check for splattered solder
Check for broken inductor
Swap capacitors: are they the same across the v1.1 and v1.2 boards? Any difference between the caps on these two boards and the new combo wombo T3A + T3B that they made? Or would that be classified as the v1.3 board? EDIT just dug through the posts, the T3A + T3B is a separate board with a v1.0 designation.
Anything else?
« Last Edit: November 02, 2023, 02:18:58 am by DarkKing202 »
Offline ma_ko
« Reply #1062 on: November 04, 2023, 08:49:47 am »
Hey, did anyone have a problem where it does not want to exit sleep/dormancy mode? All of sudden after turning it on it stays in dormancy mode and won't exit even if i remove the handle from the stand. Is it something inside making short circuit? For now i've done a factory reset but it changed the language to chinese. It didn't help though
EDIT: Updated from 1.26 to 1.34 and nothing :(
EDIT2: Here's the video if anyone's interested: https://youtu.be/mr_ccOohBA4
« Last Edit: November 04, 2023, 10:14:00 am by ma_ko »
Offline ndarjo21
  • Country: id
« Reply #1063 on: November 06, 2023, 12:50:51 pm »
try change any of this?
Offline tony359
« Reply #1064 on: November 07, 2023, 11:45:56 pm »
Did you check if the wire going from the cradle to the station is wired in the correct hole at the back?
As @ndarjo21 said, try disabling standby altogether (there are two menus, one is the standby temp, one is "dormancy" when the tip is completely turned off).
I don't know what happens if the cradle wire is unplugged, I suppose the station would not sense that the handle is in the cradle so it might be a test to do.
Offline ma_ko
« Reply #1065 on: November 08, 2023, 01:46:07 pm »
I tried with a cradle wire unplugged but the station show that it's unplaugged and won't let me do anything. I fiddled a bit with dormancy setting and set it to 380C in dormancy mode, and actually it works. It still shows dormancy all the time and it's hardcoded for that temperature after turning on but at least I can solder now. Now i think whether to order new cpu and reflash it (i heard it's the problem) or save money for a new station. For now I'll keep using it like this
Offline ndarjo21
  • Country: id
« Reply #1066 on: November 08, 2023, 01:54:12 pm »
easy way to troubleshoot is try check continuity between the handle and the jack (if the handle easy to disassemble). or just try another handle.
Offline tony359
« Reply #1067 on: November 13, 2023, 10:02:25 pm »
I tested on mine, the iron works with the cradle disconnected as I suspected. It just never goes into standby as it never senses the iron in the cradle. You can also disable all the standby and "eco" (this is how it's called in latest SW) so it never goes to sleep.
The fact that yours shows in the cradle all the time seems to indicate an issue with the main PCB I believe.
Offline McCarthy
« Reply #1068 on: November 23, 2023, 06:28:51 am »
I just returned the new Weller Smart station, was a huge mess, and now I have to start over with my research. Seeing that JBC is screwing people over with the controller / firmware / features on the DDE station, I may just cheap out and get this AiXun T3A.
At first I was glad to find this thread, but if I have to read all those 40 some pages, my head will explode.
Maybe somebody can give me a short summary on this unit.
Is is good after all? Is the overshoot a real issue for board level repairs on GPUs? And lastly, will genuine JBC handles work on the AiXun T3A?
Offline tony359
« Reply #1069 on: November 23, 2023, 11:16:33 am »
Not trying to advertise my own video but I found the T3A pretty bad at a few things, I'm not sure I would recommend it - unless you are aware of the issue I found when working with ground.
After using it extensively, I wouldn't buy it again.
https://www.eevblog.com/forum/reviews/aixun-t3a-misbehaving-on-grounded-pcbs/msg5146788/#msg5146788
The following users thanked this post: McCarthy
Offline tony359
« Reply #1070 on: November 25, 2023, 08:12:17 pm »
Aixun has released software 1.35.
Any feedback on that?
Offline c0d3z3r0
« Reply #1071 on: November 26, 2023, 11:46:32 am »
Looks like they modified C245 heating again. Maybe they fixed the weird behaviour introduced in v1.34?
1. Optimize 245 control heating;
2. Optimize the "automatic temperature compensation" function of 245;
Offline tony359
« Reply #1072 on: November 26, 2023, 05:18:24 pm »
well, my JBC tip reads 420 when set to 360 (I have reset the unit after the update) and if I cool it down with a sponge momentarily, the temp drops to 380 and then spikes back to 420.
And the display of course doesn't reflect that.
With ground nearby, I see the same power spikes and - again - the display doesn't reflect that.
It's the same rubbish as before. I'll go back to 1.33.
I'm also noticing that 1.34 has disappeared from the list.
« Last Edit: November 26, 2023, 08:22:57 pm by tony359 »
Offline c0d3z3r0
« Reply #1073 on: November 26, 2023, 10:04:08 pm »
 ;D Looks like it was a good plan to not upgrade after v1.26
Offline tony359
« Reply #1074 on: November 27, 2023, 11:14:54 am »
I wish I could, when I downgraded before 1.33 I think, the display is unreadable, they must have changed something there and only latest FW is supporting it.
