Author Topic: xytronic lf-861d any good?  (Read 1214 times)
Offline MichaelaudioTopic starter
« on: January 03, 2023, 09:07:48 am »
Has enyone get their hands on the xytronic lf-861d hot Air Station? I havent found much on Google, however i kinda like the Design and i found it on a Shop Website Here. Just wanna know If its reliable, before i spent 320$.
Offline wraper
  • Country: lv
Re: xytronic lf-861d any good?
« Reply #1 on: January 03, 2023, 09:13:17 am »
Better buy original Quick 861 which is known for excellent performance and reliability. https://eleshop.eu/quick-861dw-hot-air-station.html Other similar stations are are clones of it, not to say it makes no sense to buy a clone at such price. Also lack of physical buttons is a big no.
« Last Edit: January 03, 2023, 09:15:50 am by wraper »
« Reply #2 on: January 03, 2023, 09:27:33 am »
It would be my first hot air station, u say the touch Display would be a pain soon?
I read, that the atten is more or less the same, than the quick, but at a lower price. The xytronic catched my eye too, bc of the Minimum of 1,5L/min. Atten has Minimum of 20, the quick 1L.
But i dont really know how low u have to get, bc of my lack of experience.
Offline wraper
  • Country: lv
« Reply #3 on: January 03, 2023, 11:46:12 am »
I don't know any use case where airflow below 5-10l/min can be advantageous. Below 20 l/min is quite niche use and most likely it will be fine with 20l/min anyway.  For SMT soldering I use around 60 l/min in most cases, 120 l/min for heatshrink and fast desoldering of something larger. Atten ST-862D is pretty good apparently. However Atten is known for selling a lot of low quality equipment, but lately they seem to be targeting higher price segment with better quality equipment.  If you want to save some money ST-862D is a good choice. I don't see a reason why you would chose Xytronic over Quick or Atten.
« Last Edit: January 03, 2023, 11:48:52 am by wraper »
The following users thanked this post: Michaelaudio
« Reply #4 on: January 03, 2023, 12:34:08 pm »
The quick is 1-120l/min. Well guess ill Take the quick then👍🏻
Offline Wallace Gasiewicz
« Reply #5 on: January 08, 2023, 05:10:54 am »
Outside of haveing to replace the hot air gun element twice and find a new transformer (part not available from XYtonic) and  the on off switch broke, no other problems with our Xytronic station in a repair shop.
Not your model but hot air and solder iron station.
Oh, forgot had to replace the iron also twice.
Good Luck
Offline pope
« Reply #6 on: January 08, 2023, 02:28:40 pm »
Good Luck
haha
