I'm currently trying to determine optimum chassis size, and the implications of one choice vs another.
Options
Small Chassis Approach: (using the regular 38mm X 88m size that most T12 stations use)
Chassis Size - 150mm X 88mm X 38mm (160mm length if space between PSU and controller board is too cramped)
Controller board - KSGER V2.1S with STM32 controller chip (to be used with DavidAlfa's custom firmware)
PSU - Meanwell RPS-200-24 (200W fan cooled, 140W passive cooled) -
DatasheetPSU Mounting - PCB Standoffs or Spacers with 1mm clear acrylic plexiglass to isolate the bottom of the PCB from the chassis.
Problems - Rear panel space is limited. Using an IEC connector with a fuse is impossible without simplifying the options/goals. With a smaller IEC connector it may work. The RPS-200-24 has two internal fuses, so a third in the IEC isn't necessarily required. Chassis space may also be tight. There is the possibilty of making it fit but it could sacrifice some of the modular aspect. With no space for a lot of cable connectors that allow quick plugging or unplugging. The controller board needs to be able to be connected/disconnected. The rest, not so much. The positive with this PSU is that there is some space on the side for some wiring and connectors, depending on how big they are.
Large Chassis Approach: (using a larger enclosure with a bigger PSU)
PSU - Meanwell RPS-300-24 (300W fan cooled, 200W passive cooled) -
Datasheet Chassis Size - Haven't got that far yet, because a smaller enclosure is preferred at this stage. But for this PSU, height needs to be 45-50mm or more.
Problems - There are likely enclosures out there that could work, or even a 3D printed enclosure. The main advantage would be more rear panel space for connectors and more headroom, but the PSU seems overkill and everything else is a disadvantage. Also, the 300W version has a built in 5V standby circuit, and I'm unfamiliar with how this would work, and if it would require more space or wiring.
Attached below is what I have so far in terms of trying to size everything for a small chassis approach. Trying to keep it properly scaled to get an accurate idea of what space there actually will be. The rear panel is unknown, I haven't had time to look at different IEC connectors yet to see what may or may not fit.
I will try to use this thread as a progress log, tracking if there is a problem or a solution that works well or not. It's been many years since doing anything like this, so I'm mainly doing it as a bit of fun and to learn. I haven't committed to doing it yet, it's in the planning stage. There are many simpler options. But it can also be fun to push the limits and see what is possible.
