Just received an order for an anti-static mat bought from Aliexpress. It has 2 layers, the material seems to be rubber.
These are the specs from the vendor:
1x Anti-static ESD High Temperature Resistance Mat 60cm x 100cm + Ground Wire + ESD Wrist
Description:
100% brand new
Type :Anti-static Mat
60cm x 100cm
Thickness: 2mm
Weight: 1850grams / 1.85kg
Temp resistance: 380c
The Anti-static Mat is acid resistant, alkali-resistant, anti chemical flux, wear resistant, easyclean.
It was about 35 USD with free shipping. The top green layer is very elastic, so even with needle sharp probes it is almost impossible to pinch. The bottom layer is slightly conductive, black, and feels like rubber. The mat is heavy and flexible, it lays flat on the bench under it's own weight. It can stand a 350*C blob of solder for a few seconds without any damage. Mine came with a small fabrication defect, but this is another story.
The problem is THE SMELL. It has a very, very strong smell, like new car tires smell, but way, way more smelly.
I put the mat on the workbench, arrange all the tools, then after a couple of hours I undo the whole bench, and took out the mat because I couldn't stand the smell any more. All the time the doors and the windows were open.
I let it outside over night, but in the morning the smell was the same. Then I hang it in the direct sunlight, with a big fan to blow over it. For now, it has spent one full night outside, then 6 more hours outside in the sun with forced ventilation. It still smells as strong as yesterday.
- Could anybody that own an expensive branded mat please tell me if the expensive ones smells the same?
- Did anybody else have the same problem with anti-static mats?
- Is there any other way to get rid of the smell?
- How long will this smell last?
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
![](http://i67.tinypic.com/2ex8ow9.jpg)
![](http://i66.tinypic.com/149vwnd.jpg)
![](http://i63.tinypic.com/29p702r.jpg)
