Lots to be learned from watching plenty of Tony's other videos even if you are not that mechanically minded, the methodical approach to a problem to then create a solution with a good dose of humour makes good viewing.
Thats true, his videos are easy to see, no headaches for long videos or a storm of information. Lots of fun there!
The $350 is something for your budget but if I was buying or building new I would be going most likely go non Chinese origin Linear at this time, give it another few years to sort out quality and Chinese would also be fine. In my case I brought secondhand with $4-500 worth of tools and collets for about $1200 USD all up locally so I considered myself to have plenty leftover for upgrades if needed later.
Got it, i will skip this as i can upgrade latter too, not a question of money, but more trouble free.
I brought linear rails from china for my 3d printer, and i notice them bad quality in terms of accuracy and smooth (3 different sellers, both bad). Easy to lose balls, so i buy ceramic balls to reball when need too.
Couple of things you should check.
The photo above of the Z axis stepper appears to be smaller than the one shown on an earlier link? Perhaps ask them to clarify what steppers they are offering. I think your photo is of their smaller format one? https://www.chinacnczone.com/en/chinacnczone-cnc-3040-mini-cnc-jewelry-engraving-machine-with-2200w-water-cool-spindle-for-sale_l302_p210.html It looks a little small for a 2.2kW spindle?
Yes, the first photo was to show spindle only, he maybe took from the first machine he near by.
The motor close up was also requested by me, i ask for the motor used on the machine (6090)
Anyway if motors not suitable i will sell them and but proper ones, the LDO-57STH86 was on my list.
I will be happier if structure and build is exceeding than get a wrong or bad stepper (things i can upgrade easy and cheap)
Major thing to check they seem to be claiming Mach 3 compatibility with their controller card. Double check with them or it can add a chunk more to what you may need to spend to get good functionality later. I am not sure of how Mach3 and other Cards work regards to costs as mine doesn't run Mach3. If you can avoid needing to buy a new card at least initially and it works with Mach 3 then great. Mach 4 seems to be out too.
It's really Mach3 but cracked, all this machines work same way, but i asked anyway:
Yes, our Mach3 is a cracked version, but don't worry, this is completely usable, is really compatible with this cnc ,without any problems, our cnc6090 supports mach3 software, does not support macn4 software.
I also use that to ask you, i never used Mach3 it seens old but capable. If i discard control box from seller and use Blackbox from openbuilds and GRBL is a good choise? I see their software is good and modern, and blackbox seens well built and lot of options, capable of drive every component from that CNC, inc. software spindle speed, and WC. Instead their controller, WC and tool fluid is AC connected, no monitoring or software controled.
https://openbuildspartstore.com/blackbox-motion-control-system/https://docs.openbuilds.com/blackbox/#0welcome.htmlOne good thing for sure is know what i'm using and buy a good power supply too... But 24V limited!
Or maybe i can upgrade it latter too if i don't like it, and sell parts at ebay...
If you are buying a spindle from them with a chuck then get a range of collets while you are going as they will generally be cheaper than buying locally for you. For Tooling you will get what you pay for at this time and maybe go local and branded for that.
Another few Videos that are worthwhile is this one and some more recent ones on his channel. Far more rustic than Tony's but down to earth and it works.
I will not, will buy a better one for work metal a little better, the RTM-80-2.2:
https://www.aliexpress.com/item/RU-ship-Quality-Waterproof-2-2KW-Water-Cooled-CNC-Spindle-Motor-Carved-Metal-4-BEARINGS-ER20/32902402580.htmlA bit longer, but the head have full cover and less play.
The discount from removing spindle is 90USD, which is low compared to his acquisition cost.
5.30am here, tomorrow i will continue with videos, i'm learning good stuff here.
Belive or not i have ask same question on a CNC dedicated forum, 0 replies, topic is 1 day age.
And in this good forum more eletronic based i got a instant worth reply
Thank you
