Author Topic: Neewer TT560 camera flash - How bad can a $30 flash be?  (Read 4942 times)
Offline NerullTopic starter
« on: March 12, 2015, 02:09:09 am »
Full album here: http://imgur.com/a/XHrKw
My favorites:
Milled part numbers:
Globs of flux between 320V and ground:
Blew a chunk out of my screwdriver with this thing, even without a full charge. Guess its time to build a discharge tool.
Fun with high voltage and solder balls:
Offline SteveyG
  • Soldering Equipment Guru
Re: Neewer TT560 camera flash - How bad can a $30 flash be?
« Reply #1 on: March 15, 2015, 09:39:28 am »
We bought some of these (I think it was the 690 model though) for a project at work along with the power supply. The power supply had 350VDC on a connector with exposed pins  :--
When we linked some of the flashes together with hot-shoe attachments two of the flash units blew up and the power supply took out the 32A type C MCB  :clap:
Canon flashes were perfect.
« Last Edit: March 15, 2015, 09:41:44 am by SteveyG »
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline retiredcaps
« Reply #2 on: March 15, 2015, 07:31:03 pm »
Care to share a picture of the damage to the screwdriver?  ;)
