I think you’re worrying unnecessarily. Soldering stations are fundamentally extremely reliable, and the thing most likely to fail is probably the heater — and in the 951, each tip is a heater, so if one fails you just replace the tip. People routinely use soldering stations for decades. Often the limiting factor is that the manufacturer stops making tips for them!
