Author Topic: Soldering Station Digital DC Controller for HAKKO 936 Compatible 907 Iron Handle  (Read 14587 times)
Offline nukieTopic starter
Interesting?
http://www.ebay.com.au/itm/140728043102?ru=http%3A%2F%2Fwww.ebay.com.au%3A80%2Fsch%2Fi.html%3F_trksid%3Dp3907.m570.l1313%26_nkw%3D140728043102%26_sacat%3D0%26_from%3DR40%26_fvi%3D1&_rdc=1#ht_5960wt_1133
Soldering Station Digital DC Controller for HAKKO 936 Compatibles & 907 Iron Handle
This auction is for A CONTROLLER ONLY and DOES NOT include any iron handle, power adapter, etc.
This compact digital soldering iron controller can be powered by a common DC power adapter or a cigarette lighter cable.
Inexpensive Hakko 936 compatible iron handle having a standard 5 pin plug can be used directly.
- Features -
1. Compact size and excellent portability
2. At least as long as 2~3A,  a variety of DC voltage sources  can be applied.
3. Having excellent performance, widely used and inexpensive HAKKO soldering iron handles can be used.
4. Easily turn on/off the heater by clicking Stand-by button.
5. After 60 minutes, the heater automatically power off to save energy and protect the iron tip.
- Specifications -
1. Power consumption 60W
2. Input voltage DC 10 ~ 24V 2~3A (We recommend DC 19V 3A)
3. Temperature range 200 ~ 480 degree C
4. Size : 45 x 92mm [WxD]
1. The function description
- Temp- : Decrease the temperature setting value
- Temp+ : Increase the temperature setting value
- Memory : Set the temperature to the value in the memory.
    Push and hold for 3 seconds then memorize the current temperature setting value.
- Toggle Standby : Easily Toggle between the standby mode(Heater-Off) and the normal operation mode(Heater-On).
2. Socket for the standard Hakko 5 pin plug
3. Supports 2 standard power adapter jacks (Don't use them together)
4. Usage example (Iron handle or power adapter are not included)
5. Description of LED display and messages.
6. If the plug of the iron handle is too short, please remove the cap.
7. With a cigarette lighter cable, it can be used using a car battery.
« Last Edit: October 08, 2012, 05:17:03 am by nukie »
Glad to see that they have a genuine 907 Iron Handle in the picture  :D
Offline Amarbir[Lynx-India]
  • Country: in
  • Indian Dealer
    • Lynx-India - Visit Us For Not So Boring Electronic Instruments
Hee Hee Just The Handle Lol
Regards
Amarbir Singh Dhillon [ Lynx-India ] , Chandigarh [ India ] - > www.lynxdealerstore.com , www.lynx-india.com
Indian Distributor For  [ Autoelectric , Sofitech , IDEOfy ,Peak Electronic Design [UK ] , Anatek And Creatronica ]
My Electronics Blog - > www.lynxchandigarh.com
Offline amyk
Seems a bit overpriced... and I wouldn't be surprised if they just took one of the many open-source iron controllers around. Running the heater on DC shouldn't be a problem, but I think they should at least heatsink the power transistor (even the 936 clones, which cost less than this for the entire transformer, controller, iron, and stand, have a heatsinked triac).
Interesting concept like the 9936, I bet Hakko never thought their irons would be cloned and shanzhai'd so much. Then again, imitation is the sincerest form of flattery...
Offline T4P
  • Country: sg
    • T4P
Fairly ok price for a digital one  :o But i've seen them around and they can't be trusted for continous use
Offline poptones
Interesting. In US you can get one with the case and knob for 34.95, appears to even have the Hakko front panel. It's funny, with the one K blacked out it looks like "HAKD."
Don't they need a power transformer? This listing doesn't show one. Seems like by the time you buy a transformer and iron you might was well spend 80 bucks on an 888.
Offline T4P
  • Country: sg
    • T4P
You need a 10-24V 3A power brick which probably is a modern laptop power brick (HP started it first!)
But i'll say 24V is the best, because the heaters are 24V native, might as well run them that way but it seems like it's a boost converter so i doubt a heatsink is needed.
Plus ya need to get a original type 936 DIN plug handle, it adds up but hey. If you have like a broken original 936 this could be somewhat useful especially if you have a 5mm brick with 24V lying around, and i have seen shitloads of exact clones of the 936 so that DIN connector is just ... nah, that iron is probably a clone in the picture
But heck! You can use it in your car. I won't dismiss the fact that it probably won't filter the output because DC can oxidise heaters in short order
A 24V 2A power brick is cheap as chips i'll tell ya, don't need a "24VAC" tranny like the 936s do and that's a good thing because the original 936s weigh 1.4kg
The schematic you posted is a clone's schematic right? The original hakko uses a TRIAC driver but if it opamps can do the job i'm not complaining
Offline amyk
In the video the heatup time is extremely slow... but that might be because he used a 12V supply so the iron is being driven at 1/4 power (or less).
What?
What makes you think its a boost converter? Obviously your browser does not support image or you have problem with the low rez image. A lot of well designed boost converters requires only thick copper tracks of the PCB to dissipate heat, heatsinks are not always required.
Tell me which boost converter work without magnetics except for charged pump based config.
« Last Edit: October 09, 2012, 10:48:22 am by nukie »
Offline T4P
  • Country: sg
    • T4P
What?
Free hanging heaters that is ...
Didn't see the video so now i'm led to believe it's direct drive ... it's extremely slow the way i see from his video he probably used 12V, i make assumptions all the time looking at specs and silly me forgot there isn't a inductor :\ It took him 4+mins to do what my 936 does in 20secs! (Oddly i have the fast-heating variant too)
« Last Edit: October 09, 2012, 11:26:45 am by T4P »
