Author Topic: Problem with focus nikon smz-1  (Read 1723 times)
Offline toly084Topic starter
  • Country: ua
« on: August 18, 2017, 04:34:23 pm »
Hi all, I need help. I have nikon smz-1, this microscope do not have focus on all range of zoom. First, the picture in oculars was misalign, I solved this. But without manual it is enough hard. May be someone have manual for repair oc this microscope? I found on this forum manual for smz-10, but it is different.
Offline eKretz
Re: Problem with focus nikon smz-1
« Reply #1 on: August 19, 2017, 10:42:51 pm »
I have one with the same issue. I have done some tinkering with adjustments but haven't found a way to fix it either. I also have a convergence misalignment at one end of the zoom. Did you find how to adjust that perchance?
