Author Topic: Agilent DMM users question  (Read 2953 times)
Offline PetrosATopic starter
« on: January 28, 2011, 04:15:10 am »
For those of you who own recent Agilent multimeters, could you try these experiments and let me know what happens?
1) Take an incandescent light bulb and check it on the continuity setting. Does it beep continuity or are you just getting an ohms value? If you have some way to test what ohms reading sets off the beeper and whether it always reacts at the same reading, that would be helpful too.
2) Hook the leads up to some sort of switch and check whether the continuity beeper works if you "test" the switch a number of times in succession.
These are both cases where I've had issues with my Agilent clamp meter in continuity mode (which I don't use very often). It won't beep for a good light bulb (easiest way to check...) and I recently installed some industrial grade door switches that I thought were malfunctioning because my clamp meter (2.5 m away) wasn't beeping every time I closed the switch. Needless to say, it was a pain in the ass trying to figure out the door switches till I realized it was the meter acting strangely.
Thanks!
I miss my home I miss my porch, porch
Offline EEVblog
Re: Agilent DMM users question
« Reply #1 on: January 28, 2011, 05:34:20 am »
From memory my Agilent meter allows you to chose the continuity threshold level.
Dave
« Reply #2 on: January 28, 2011, 05:54:49 am »
Ok, I thought I had heard that somewhere. I thought I could do the same with mine, but alas. I must have been thinking about your review. I've read the manual and service guide and there doesn't seem to be any menu for that.
