Author Topic: Advice UPS teardown  (Read 4080 times)
Offline singeraTopic starter
Advice UPS teardown
« on: October 15, 2012, 11:30:21 pm »
hey to all
I got last week Advice 650VA PRV UPS that need to replace his battery (my work bought a new one from the same model and throught this one) I will bring this unit to my girl friend after I will replace the battery (12V 7AH).
my computer is connected to the older version Advice 650VA PRPC UPS but it better (and also need a new BATT).
PRV on left PRPC on right:
PRV has On/Off SW PRPC has multi function switch (On/Off, test, alarm off).
PRV has 3 LED PRPC has one single color multi function led.
PRPC BACK:
has IEC fused input, two IEC out, modem line/ethrnet suge protection, USB control on main board.
PRV BACK:
has IEC fused input, 4 IEC out,  USB control on daughter board.
PRPC inside:
has multi tap transformer for voltage regulator.
PRV inside:
has single tap transformer but much smaller.
the PRPC model is from 2006.
the PRV model is from 2009.
