Author Topic: Completely non-sketchy $20 2700V transistor breakdown tester (Emeco)  (Read 9466 times)
Offline DaneLaw
Re: Completely non-sketchy $20 2700V transistor breakdown tester (Emeco)
« Reply #25 on: August 18, 2024, 08:12:16 pm »
Also picked one of these up.. looks like there is some differences, in regards to the previous models in this thread.
Fx.
* Banana jacks
* 40v to 3665v  (its a screamer)
* 0 to 5mA
* Decimal tolerances (below 1000v / 999.9v)
Model NY35, the older models seems to go from 120v to 2700v and 0 to 3.8mA, and volt reading in full digits.
It is able (to an extent) to light up some of these quite old gas tubes, that I use for crude spectroscopy (atomic spectra-emission lines).
It struggles to keep the charge on fx Mercury and Helium, while Neon lit up well.
Neon_ - Mercury_
Helium_
The accuracy seems fine.
Prices were around 18$ to 25$ incl. 25% EUVAT / Delivery (varies depending on sale, coupons, aliexpr.)
Worth noting the listings on the unit above, claimed two LIPO cells, it ain't - just a single..will try to post some pictures from the internals.
Its not that useful for such gas-discharge-tasks with so little ampere, I tend to use a rigged HV-tester which I can dial up from adj. powerbanks..
« Last Edit: September 04, 2024, 08:18:07 am by DaneLaw »
The following users thanked this post: thm_w, nidlaX
Online nidlaX
« Reply #26 on: September 02, 2024, 10:17:02 pm »
Damn, one of these testers + that gas tube variety box would make for a great Christmas present. ;D
Offline tooki
« Reply #27 on: September 04, 2024, 06:08:23 pm »
Fx.
* Banana jacks
* 0 to 5mA
Nice pix! That's also rather daring of you, using 30V-rated banana plugs for nearly 4kV! :P
