Author Topic: Review of dirt cheap chinese "UD-B DDS" freq gen, off from eBay  (Read 5181 times)
Offline MashpriborintorgTopic starter
Hi, I got this dirt cheap frequency generator, and I believe such an unusual weird thing deserves a review.
Pros:
- Dirt cheap (45 euros including delivery),  and yeah it makes a signal as far as I can see
- Built quality is cost effective but not too catastrophic, actually I was expecting something worse
- Good BNC sockets, and good Arduino compatible LCD panel.
- Came with a decent quality USB powerbrick and BNC to crocodile cord, which are always handy to have.
- Frequency, up to 2MHz can be set digit by digit
- Probably enough for basic hobby use
Cons:
- Came raw in a air bubble enveloppe, without retail box, without user manual
- User interface is minimalist and not so convenient
- The rotary buttons are not easy to set, no readout of the offset and amplitude, oscilloscope needed for it
- Provided USB cord was not the correct kind for the device !!! but seems to be ok for an Arduino, at least
- Lack of functions
- Lack of a hi-stability oscillator, seems it runs from a regular quartz
- Square wave shows ripple above 1 MHz
- It's not a Tek or a HP :-p
Here are the photos:
Offline T4P
  • Country: sg
    • T4P
Re: Review of dirt cheap chinese "UD-B DDS" freq gen, off from eBay
« Reply #1 on: March 15, 2012, 11:38:50 am »
Altera Max !  ;D
Offline cybergibbons
« Reply #2 on: March 15, 2012, 11:52:38 pm »
That looks like some fairly strong ringing on the square wave...
alm
  • Guest
« Reply #3 on: March 16, 2012, 12:21:40 am »
Does terminating the output into 50 ohm at the scope end reduce the ringing?
Offline Kozmyk
  • Country: wales
« Reply #4 on: March 16, 2012, 01:05:33 am »
I bought one last year - UDB1105 5MHz with Sweep
It's OK up to around 1MHz. After that it gets noisy and ringy.
Terminating the line did nothing for me.
The sweep on mine has a fixed range. I'll have to fire it up to check the start/end points.
Has it's uses though (audio injection)
Now the Hantek DDS-3x25 - that does the business (with the Goltek software)  :)
Offline Kozmyk
  • Country: wales
« Reply #5 on: March 18, 2012, 03:12:41 am »
8) at least good to know it has some use :P
Credit where it's due.  ;)
