I bought a Geeetech dual extruder. I have trouble keeping it accurate. It never prints the pieces the same size. Lately, it prints the pieces, and then starts skipping the g-code and messes up. I have to carefully watch it, and when it does, stop it real quick, find the line it messed up on, erase all lines before, copy and paste the start codes and readjust the start height, so it can pick up where it left off so I don't waste all the hours it has already done.
I have found that ultra Hold hairspray works alot better then a slurry of acetone and ABS for holding down the ABS when making parts. Just spray the hairspray on the heated bed. works like a charm. forget the slurry mix or glue stick. use hair spray!
Waste of money.
Ive been designing my own. 5-head. Easier to adjust and change out the nozzles. Enclosed with heated temp control. Making for myself. Just gotta find someone to make the aluminum parts once I finish designing them...Here's a sneak peak......
