Author Topic: 24V DALI radio module  (Read 1688 times)
Offline ocsetTopic starter
« on: March 22, 2018, 10:32:58 am »
Hello,
Does anybody have a datasheet for any 24V fed DALI radio module, which receives DALI
   commands via the mobile telephone network and then DALI dims a DALI dimming
bus, so that a lamp connected to that DALI dimming bus can be dimmed.
I think theyre about 10.5W  max power. And they are European Mains input.
« Last Edit: July 07, 2018, 09:06:24 am by treez »
Offline Nikhil
Re: 24V DALI radio module
« Reply #1 on: July 04, 2018, 05:05:55 am »
What do you exactly mean by a DALI radio module?
Electronics engineer, reinforcing fundamentals and looking for projects in any field.
The following users thanked this post: ocset
Offline TJ232
  • www.esp8266-projects.org
    • ESP8266 Projects
« Reply #2 on: July 04, 2018, 05:13:28 pm »
Treez style questions where you need to find not only the answer but also the related correct question.
Probably he wants a DALI Gateway, that can be a DALI protocol to GSM, 3G, GPRS, RF ISM band or WIFI, or bluetooth or all of them Gateway/translator.
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
Offline Nikhil
« Reply #3 on: August 09, 2018, 09:29:16 am »
I guess this can work for you if you'd like.
https://www.helvar.nl/files/_downloads/191xx-192xx-193xx-290x-datasheeten.pdf
It uses the DALI protocol, controlled via Bluetooth.
