I have seen some very useful (but expensive) specialty filters at Edmund Optics, but these are either unmounted or designed to be mounted in optical lab equipment in special optics-lab table mounts. As a result they are not threaded filters as needed to attach to a camera. Is there some website that will take custom requests for filters? For example my camera has 52mm diameter threads, so the filter will need to fit this specific thread size, and I'm interested in the filter being made of UV-PASSING glass (not the normal so called "UV filter" for cameras that blocks UV). I have found a few websites that sell pre-made UV-passing filters for cameras, but the problem is these have the unfortunate problem of also passing quite a bit of IR light (sometimes sold with 2 pieces of glass, one passes UV and IR, and one is made of IR blocking glass).
In my research for a better solution than this, I found one type of filter glass that actually has quite decent rejection of IR light, while passing UV quite well. That filter glass is Hoya U-340. But there's one problem. Unfortunately I have NEVER found a website selling a filter made out of this Hoya U-340 glass mounted in a threaded filter ring designed to go on a standard camera. I might need to custom order the glass cut from Hoya, and then separately purchase a filter ring to mount it in. But if it wasn't cut to exactly the correct diameter it could be too big to fit the filter ring, or so small it rattles around inside the filter ring. It would be nice if there was some company I could go to and custom order a filter with the right type of glass, with the right thread diameter and they would custom make the filter for me. Does anybody here know if such a company exists? And can you link me to their website?
