Author Topic: [Pictures] Fluke 233 Teardown  (Read 9274 times)
Offline Richard W.Topic starter
« on: December 17, 2011, 07:58:46 pm »
Hello,
here are some pictures of a Fluke 233 multimeter.
All pictures are also available in a higher resolution (4000*3000 pixels), please feel free to ask.
« Last Edit: December 17, 2011, 08:08:17 pm by Richard W. »
Re: [Pictures] Fluke 233 Teardown
« Reply #1 on: December 17, 2011, 08:01:19 pm »
some more pictures
Offline phil_jp1
  • Country: ua
« Reply #2 on: December 17, 2011, 08:28:28 pm »
Thanks for the teardown pics!  :)
http://JumperOne.com - Electronic projects, tutorials, hacks, etc.
Offline grenert
« Reply #3 on: December 17, 2011, 09:34:24 pm »
Thanks for the pictures!
I wonder if the shielding around the big capacitor and the resistor network is for GSM radiation  ;D
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #4 on: December 17, 2011, 09:39:07 pm »
Is it just me but the range switch looks like not Fluke quality standard ?
Oh, the joy of sending various electronics to silicon heaven
« Reply #5 on: December 18, 2011, 02:52:56 am »
Quote from: hacklordsniper
yes, looks a little bit flimsy compared to the switch in the 28x  [https://www.eevblog.com/forum/index.php?topic=3941.0]
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #6 on: December 18, 2011, 06:45:39 pm »
For all it's faults though, the range switch feels good. I suspect there are just fewer traces because a lot of the switching is done electronically rather than mechanically.
Alex
  • Guest
« Reply #7 on: December 18, 2011, 07:07:30 pm »
Did Fluke ever make a comment on the ridiculous consumption when the 233 is off?
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #8 on: December 18, 2011, 07:11:15 pm »
The only reason to open up a Fluke will be just for checking the PCB revision.  ;D
Thanks Richard, I did save this page for off line use,
I do safe-keep allot of technical material in my hard drives.  ;)
(The current file size is very good)
« Last Edit: December 18, 2011, 07:15:03 pm by Kiriakos-GR »
Offline Zad
« Reply #9 on: December 19, 2011, 12:41:46 am »
They did indeed. I complained about it on the Element-14 forums and a Fluke representative popped up and immediately went on the defensive. He said it was a function of how the remote system operated, and their consumer research had found out that users wanted it that way. Now, I would like to know what questions they asked, because I can't imagine they asked "Do you mind if your meter eats a set of batteries every few weeks". It was clear from his response that they weren't interested.
So far as I can see, the units chat several times a second, and if communication is lost the RF turns on. Running the units once a second and at reduced output wouldn't have been difficult.
Offline samgab
« Reply #10 on: December 19, 2011, 02:00:19 am »
The 233 is made in China isn't it? The switch looks very similar to the range switch on the cheap Chinese-made Fluke 15B and 17B.
See the picture of my 17B below:
Offline Zad
« Reply #11 on: December 19, 2011, 03:44:22 am »
Mine says "Made in USA" moulded into the case.
Offline samgab
« Reply #12 on: December 19, 2011, 07:33:04 am »
Oh, my mistake then. I must have been thinking of some of the other newer models, maybe the electricians 117 etc.
