Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
Fixing a LG TV
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Fixing a LG TV (Read 2715 times)
ResR
Regular Contributor
Country:
-Artificial_Intelligent-
Fixing a LG TV
on:
August 17, 2013, 04:35:50 pm »
I'm trying to fix a LG 19LS4R TV, that had bad caps (replaced) and broken 3,5mm audio jack with 8 pins, but I can't get sound out to the internal speakers. There is no burned components. Does anyone knows the pinout for the 3,5mm audio socket so I can at least get sound to speakers?
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/1004822_508292735916838_1178098311_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash4/1005916_508292692583509_259575134_n.jpg
Logged
fluxcapacitor
Frequent Contributor
Country:
Re: Fixing a LG TV
Reply #1 on:
August 17, 2013, 05:45:18 pm »
I don`t know the pinout ,but heres the schematic .
http://elektrotanya.com/lg_19ls4r_lp69c_chassis.pdf/download.html
Scoll down page where it says : This file is downloadable free of charge... processing (please wait)
(You are not logged in, only 2 downloads per day possible for you.) The link will appear after a few seconds.
Good luck.
Logged
ResR
Regular Contributor
Country:
Re: Fixing a LG TV
Reply #2 on:
August 17, 2013, 07:19:17 pm »
Thank you for your assistance, the schematic really cleared it out. I have to bridge the HP_DET with ground to make it work, if I readed the schematic correctly.
Edit: Bridging HP-DET to ground didn't work, still no audio. Hmm...
Last Edit: August 17, 2013, 07:46:17 pm by ResR
Logged
fluxcapacitor
Country:
Re: Fixing a LG TV
Reply #3 on:
August 18, 2013, 01:26:35 am »
HP_DET goes to pin 37 of the IC ,it acts like a switch ! plug headphones into the socket and test T_Terminal 1 to pin 37
(pin4 of headphone jack touches pin 6a when headphone socket plugged in, and pin5 touches 6b) Its easier to understand that way .
Logged
Stonent
Super Contributor
Country:
Re: Fixing a LG TV
Reply #4 on:
August 19, 2013, 07:16:03 am »
Yeah, in situations like that the headphone jack usually operates like a switch to turn the internal audio off and on. I've seen them just go bad and not close completely when the plug is pulled out. Sometimes you can bend the inside parts to close properly.
Logged
fluxcapacitor
Country:
Re: Fixing a LG TV
Reply #5 on:
August 20, 2013, 02:12:26 am »
Yes,they can go bad and also get damaged easily .If you need to replace the jack, the LG part number is : 6612F00099A .
New parts:
http://north.pl/karta/6612f00099a-jack-phone-lg,736-UV-0308.html
Logged
urbis
Supporter
Country:
Re: Fixing a LG TV
Reply #6 on:
August 30, 2013, 10:49:04 am »
My first post here...
I know some LG TVs have an option in the menu to disable the internal speakers, not sure whether you've checked this?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Fixing a LG TV
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
