Author Topic: $45.40 Hot Air Reowrk Station, Youyue 858D+  (Read 2947 times)
Offline TheAmmoniacalTopic starter
  • Country: no
« on: September 02, 2015, 08:25:15 pm »
For anyone else looking for a cheap hot air station, here's a quick look at the cheapest I could find. It's a Youyue 858D+ (Clone of the Atten 858+: https://youtu.be/vva2t21sOAs?t=1s) from Aliexpress: http://www.aliexpress.com/item/220V-700W-YOUYUE-858D-ESD-Soldering-Station-LED-Digital-Solder-Iron/32373963710.html
It was $45.40 total, including shipping from Singapore to Norway. It was ordered on the 25th, marked as shipped on the 27th, arrived at the post office here in Norway on the 1st and picked up on the 2nd. Don't ask me how that happened (Would not expect it to be this fast for anyone). The seller has 100% feedback score and communication was good (responded to the message).
Pictures here:
https://www.dropbox.com/sc/1fff0gftx3y0gbg/AAA342ffmqdTA7-qeb98TBY6a
At a first test the temperatures do seem to be within +-10 C at half an inch from the nozzle.
It does have an automatic shut-off and cooling period when you put it back in the handle.
The case and front panel are metal.
Soldering on the PCB inside looks good. (only the one solder joint on the PCB inside the handle looked suspicious, but fine)
Offline electr_peter
  • Country: lt
Re: $45.40 Hot Air Reowrk Station, Youyue 858D+
« Reply #1 on: September 02, 2015, 09:42:36 pm »
Check wiring very carefully! See this thead for more info https://www.eevblog.com/forum/chat/deadly-wiring-fault-atten-858d-hot-air-rework-station/
There are multiple models of similar hot air stations - Atten 858D+/Wep 858D/Youyue 858D/Pro'sKit SS969B. Pro'sKit SS969B internals are quite nice unlike some others.
Offline GreyWoolfe
  • NW0LF
« Reply #2 on: September 03, 2015, 11:57:34 am »
I bought a Yihua 858D for about the same price and found no wiring issues.
