Author Topic: $336.10 Color 5.7" 60MHz Oscilloscope SDS1062CE any good?  (Read 3611 times)
Offline semaphoreTopic starter
  • KISS principle ... RTFM
« on: January 18, 2011, 04:35:31 am »
Just saw another low cost oscilloscope on dealextreme. Anyone own this model please write some review here.
http://www.dealextreme.com/details.dx/sku.54073
- Model: SDS1062CE
- 5.7" color TFT LCD display (320*234)
- Bandwidth: 60MHz
- Channels: Dual Channels + One External Trigger Channel
- Real-time Sample Rate: 2Gsa/s max
- Equivalent-time Sample Rate: 50Gsa/s
- Memory Depth: 18K/CH (single channel), 9K (double channel)
- Rise Time: <5.8ns
- Input impedance: 1M ohm ||15Pf
- Timebase Range: 5.0ns/div-50s/div
- Vertical Sensitivity: 2mv-5v/div (1-2-5 sequence)
- Vertical Resolution: 8 bit
- Trigger types: Edge, pulse, video, slope, alternative
- External save: Bitmap save, CSV save, waveform save, setting save
- Support 12 different languages display
- Support waveform recording & playback function
- Support digital self-tuning & Screen-saver functions
- Interfaces: USB Host + USB Device + RS-232 + Pass/Fail
- Package included:
- 1 * Oscilloscope
- 1 * USB cable
- 1 * Software CD
- 2 * Probes
- 1 * Power cable
- 1 * Chinese manual
Specifications  Dimensions: 12.01 in x 6.06 in x 5.24 in (30.5 cm x 15.4 cm x 13.3 cm)
Weight: 85.01 oz (2410 g)
Offline tyblu
    • blog.tyblu.ca
Re: $336.10 Color 5.7" 60MHz Oscilloscope SDS1062CE any good?
« Reply #1 on: January 18, 2011, 06:24:48 am »
To tell you the truth I wouldn't go for it due to the low memory. I am a memory hog nowadays.
Tyler Lucas, electronics hobbyist
Offline Nermash
« Reply #2 on: January 18, 2011, 07:42:07 am »
That  same model is also sold under Atten brand at cca 750 USD price...
2 Gs/s spec is nice, but memory depth is not...
I wonder if it is hack-upgradeable to 100 MHz like early Rigol fw versions, they should be based on the same design.
« Last Edit: January 18, 2011, 07:43:46 am by Nermash »
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: January 18, 2011, 12:01:09 pm »
I don't own this scope, so FWIW.
Siglent is Atten's brand for its scopes, it seems like a take off on 'Agilent'.   I think they are going to focus the brand "Atten" increasingly to other test equipment.
http://www.siglent.com/old/enindex.asp
At $336, I don't think its worth the money, given its only a handful of $$ different from Rigols' 1052E from the same dealer, and Rigol has a much better reputation.
http://www.dealextreme.com/details.dx/sku.30573
« Last Edit: January 18, 2011, 12:17:53 pm by saturation »
Best Wishes,
 Saturation
