Author Topic: Riden RD6006 strange failure  (Read 1241 times)
Offline bogdan2014Topic starter
« on: September 29, 2021, 05:15:19 am »
My Riden RD6006 power supply has failed in a weird way. I was powering a circuit and something shorted out on the PCB, then the PSU died. Upon inspection, there's no blown fuse, the switching transistor and diode are fine, but the auxiliary rail is shorted out. I removed most of the ICs but it's still there. Also checked the bigger diodes. There's no blown components, no burn marks, nothing really apparent.
I guess I'll have to start checking the smaller components...
Online DavidAlfa
Re: Riden RD6006 strange failure
« Reply #1 on: September 29, 2021, 05:25:59 am »
Connect another power supply to the aux power, setting the nominal voltage, and start increasing the current.
At some point the shorted part will start to heat up. Ceramic capacitors like to do that sometimes.
But, just in case, take quality pictures where every part can be read. If the damaged part blows up, and the number is no longer readable, it'll be much harder!
« Last Edit: September 29, 2021, 05:27:54 am by DavidAlfa »
Offline fixy88
« Reply #2 on: September 29, 2021, 06:45:58 am »
.... Ceramic capacitors like to do that sometimes....
Shorted MLCCs seem to be the new leaky electrolytic.... Super common fault.
Offline perieanuo
« Reply #3 on: September 29, 2021, 09:40:14 am »
i doubt it's a shorted cap, after how the short was caused, but the method of injecting dc with current limited and increased (i was lazy and i applied the nominal DC voltage on the rail with minimum 8 amps capability, the shorted component was quickly hot or even smoked)
i had a feeling not to buy riden seems i was right, they don't support those type of dut that shorts suddenly
maybe the schematic i attached seems close to yours
[edit] they say R22 should be replaced with something between 68K-100K if not already done, maybe you already know this
i added also the pdf's it's easier to follow the short
« Last Edit: September 29, 2021, 10:26:40 am by perieanuo »
« Reply #4 on: October 05, 2021, 06:35:43 am »
I think I found the culprit, this small regulator heats up. There's no short at its output, so I guess it failed. On my board it's marked B6289P, but it has the same pinout as the one in the schematic.
Offline perieanuo
« Reply #5 on: October 07, 2021, 07:02:29 am »
so you have those 8.4V on output (my schematics and yours point that same voltage)?
https://www.olimex.com/Products/Breadboarding/BB-PWR-3608/resources/MT3608.pdf
« Last Edit: October 07, 2021, 07:04:12 am by perieanuo »
« Reply #6 on: October 07, 2021, 07:06:24 am »
Haven't actually measured since even with a few volts at its input the current shoots up and the IC heats up. I assume that with the full 12V it will blow up and I don't want that. But I applied 8V at its output and there's no short.
Offline perieanuo
« Reply #7 on: October 07, 2021, 01:06:05 pm »
just disconnect that ic input from the 5V rail and apply 5V from another power supply, you'll got either 8.4V either some burnt mt3608
i suppose you verified D1, C13, but my bet is mt3608 kicked the bucket  :-DD https://www.sigmanortec.ro/Modul-ridicator-tensiune-MT3608-5-28V-2A-p158720114
Offline perieanuo
« Reply #8 on: October 07, 2021, 01:14:51 pm »
actually, it's the other way: smaller the input voltage, higher the dissipated power, so power him with 5.3V like in the schematics, this will reduce power dissipation if the ic works correctly, dissipated power is (output voltage-input voltage)*current, i suppose current drawn is determined by your load and that load is not shorted. you need to verify if load on 8.4v rail is ok
