Hi All,
I accidentally hooked my trusty old 1550 up backward to a 12V lead acid battery.
At first, it appeared that the supply survived, however I started noticing some symptoms.
-The unit turns on, all buttons and display work.
-Sometimes, the unit works normally, especially at low voltages and currents
-After a few minutes, the output stops creating current, and I cant measure any voltage with my multimeter. The unit needs to be turned off and turned back on and sometimes it begins working again. Sometimes, it will continue to produce current, but only a fraction of what it should be outputting.
Troubleshooting:
-I first checked the main board and front panel board for damaged components and burn marks. None found. There was no smoke or sound when I accidentally reversed the polarity.
-I checked the MOSFETS for shorts, and they all appear to test correctly
-I obtained the schematic for this unit, but am unsure what to check next
Do you have any advice for next troubleshootign steps? I'd hate to thow this out when it appears to be about 75% functional. Any help would be appreciated.
