Hello,
I have a problem with my Tek Scope. It shows Test 76 Fail 01. The maual says Malfunction of DMM, or if this is the only failure V/F input Multiplexer U5020 input pin 2.
I recapped the PSU and the DMM. I already changed U5020, but the fault is still there.
I can ignore the fault and use the DMM with no problems.
Does anyone have any Idea what to to?
Lenny
