Author Topic: Induction cooktop beeping noise  (Read 952 times)
Offline RobertasTopic starter
  • Country: no
« on: August 03, 2020, 01:07:14 am »
So i used a brand new iduction coock top and after i used it it started beeping like crazy from the power plug and i have no idea what is wrong whit it. i tryed unpluging it but i didnt help. i beg you from help it has been going for almost 3h now and i think im going crazy
i have a video of it here: https://www.youtube.com/watch?v=i7d-xe9CLG0&feature=youtu.be
Offline tooki
Re: Induction cooktop beeping noise
« Reply #1 on: August 03, 2020, 09:22:42 am »
I’d call that a metallic “chirping” more than beeping, since “beeping” is generally reserved for tones created on purpose, but this is definitely not intentional.
Anyway, you’ve left out some other key info: does the cooktop actually work? What are the test conditions here:  Does this sound occur only when turned on? Or turned off? (I can’t quite make out if the cooktop is powered on or not.)
It’s definitely not coming from the plug itself. It’ll be sound coming out into the cabinet where the socket is, but not coming from the plug. It sounds to me like a power supply trying to start up, but it’s also a very similar sound to an induction stove actually heating a pan. You get a similar interrupted metallic chirping when an induction stove is having trouble detecting a pan, and keeps cycling a burner on and off as it tries to turn on, doesn’t detect a pan properly, and then turns off and tries again a moment later.
It looks like it’s plugged into a 230V socket. Is the cooktop configured for 230V single-phase, or is it configured for 400V three-phase? (Some can be configured for either.)
