hi
I need some help repairing a yamaha mixer/amplifier. I attached the schematic for the power supply. The unit was powered from a crappy generator at an outdoor party and when the fuse blew of course they used a shunt. The problem is this diode - 10gl2cz47. I can't find it anywhere. It's in the upper right corner of the schematic. I found the following parts blown also - q817(2sk2842) , r872,873,874,875 so i presume ic803 is fried also. If anyone has a bit of time to take a look i'd appreciate it. I attached the datasheet for the diode. Please tell me a replacement for this diode.
Thank you!
