Author Topic: Precision drill press motor troubles  (Read 2906 times)
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« on: December 25, 2016, 05:19:23 pm »
Hey, and merry new year!
I recently, at a flea market, bought a small really hq looking drill press, and I got it for very cheap because the motor didn't work, since it 'blew the fuses'.
It's a 3-phase motor, and I assumed it was used as one-phase, and there was no start/run capacitors on it, so I suspect that's what's tripping the breaker rather than an actual winding short. I don't have much experience with mains voltage motor stuff, but I'd like to get it running, before considering getting a 1 phase replacement motor.
Here's what I can see:
    - three phased
    - one side of each of three coils shorted into star config
    - no start/run capacitors added
The coils all measure the same resistance, so I guess there aren't any direct shorts. I don't have a megger, so I can't check the insulation..
Now, there's a lot of diagrams out there for motor wiring, but I still seem to find some conflicting info.
What would be needed to get this running on a single phase?
I know it'd be running at less power, but the chuck only takes like, 4mm drills, and I mainly work in soft metals and plastics, so that's not an issue.
It's not a big motor, a tad larger than a can of soda, but it seems to be very high quality, made in Germany, and looks almost new.
Thanks in advance,
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline PaulAm
Re: Precision drill press motor troubles
« Reply #1 on: December 25, 2016, 06:13:33 pm »
Do a web search on static phase converters.  Essentially you need to connect the mains to 2 of the motor connections and use a start cap on the third until the motor is up to speed.  Once started it will keep running on single phase unless you load it down so much it drops out of sync.
You can also use a VFD, but that's a more expensive solution.
Another option is a rotary phase converter, but that's kind of overkill for one little drill press.
« Reply #2 on: December 25, 2016, 06:21:53 pm »
Manufacturers plate on the motor gives you voltages, frequency and current, and it is possible this is a motor designed for inverter use. A picture or three of the unit, the motor and the manufacturers plate of the motor would help here.
    • My channel:
« Reply #3 on: December 25, 2016, 06:33:11 pm »
Static phase converter's what I was talking about, didn't know the name, though. A lot of designs seem to require two phases, just to be certain, does this also work with one 230V phase and N?
You're right, I'll try to get those out later.
Offline Seekonk
« Reply #4 on: December 25, 2016, 08:58:06 pm »
I picked up some new really cheap 1/10 KW converters on ebay cheap. So cheap I bought three of them.  They will actually turn 1HP motors with no load.  I'd connect two wires to line voltage and a 6uF cap to the third motor wire. Connect that to either of the line powered wires. You can reverse direction by connecting to the other line.  This may have been designed to work at higher frequency.  If you have a variac or auto transformer, try it at a much lower voltage first.  Any motor has a V/f ratio. That may be the reason it blew the fuses.  Just what size were these fuses.
Offline PaulAm
« Reply #5 on: December 25, 2016, 09:14:54 pm »
A lot of these morons misinformed uneducatable individuals have no idea what they're talking about and continually confuse a center tapped grounded transformer as something providing 2 phase.   In the US you either have single phase or 3 phase if you are industrial.  Residential is almost 100% single phase.  If a US web site is talking about 2 phase go find another site.
I don't know about Denmark;  but it sounds like you have 230 single phase.  The US distribution is 240 center tapped with the center tap (neutral) grounded.  Just ignore the neutral and don't get too complicated.  It's really not hard to get it running.
230 single phase works fine.  For this case you can get away with a momentary push button and a start cap.  Use an industrial push button rated for the voltage though.  You don't want that switch welding itself closed.
The big question is the motor.  If it's set up for 240 3ph you should be fine.  If it's 480 you'll either need a transformer or you might be able to rewire it internally for 240.  Larger motors typically can be set up for different voltages, but that might not be true for your drill press.
What's the motor nameplate say?
edit: Clarified which phase converter websites I was referring to.
« Last Edit: December 26, 2016, 03:23:42 pm by PaulAm »
Offline Monkeh
« Reply #6 on: December 25, 2016, 09:23:43 pm »
A lot of these morons have no idea what they're talking about and continually confuse a center tapped grounded transformer as something providing 2 phase.   In the US you either have single phase or 3 phase if you are industrial.  Residential is almost 100% single phase.  If a web site is talking about 2 phase go find another site.
230 single phase works fine.  You won't actually use the neutral unless you have some relays that need 120V.  For this case you can get away with a momentary push button and a start cap.  Use an industrial push button rated for the voltage though.  You don't want that switch welding itself closed.
OP is not from the US. You're not looking much brighter than those you're insulting.
Offline tronde
  • Country: no
« Reply #7 on: December 26, 2016, 12:57:01 am »
Some places in Europe uses an IT distribution system. Most likely 230V 3-phase delta. When you connect 1-phase equipment to that system it is often known as "2-phase" because you connect to two of the three phases.
Yes, it's wrong because it's not technically 2-phase, but it's used to distinguish between TN-system with 400V star and neutral and the IT with 230V delta and no neutral. Both systems can be found in the same city.
Offline PaulAm
« Reply #8 on: December 26, 2016, 03:47:31 pm »
Here's pretty much the last word on building a rotary phase converter:
http://www.practicalmachinist.com/FitchWConverter.pdf
The important thing to notice from the diagram is that 2 lines (single phase) come in and a start capacitor is temporarily switched into the motor's 3rd winding to get it running.   That's all it takes to get a 3ph motor running on single phase.  The rest of the stuff (contactors, run caps, PF correction cap) are to improve safety and performance.
Commercial static converters will use a current relay to automatically disconnect the start cap once the motor is running, but it is possible to use a start push button.
If you see the names Fitch Williams or Jim Hanrahan associated with an article you're looking at good information.
Here's another link:
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
Offline EPTech
    • EP Technical Services
« Reply #9 on: December 28, 2016, 12:49:12 am »
Hi There,
If you have an asynchronous motor wonly the size of a soda can, I guess it will not be more than 250W. Using a capacitor circuit to have it run on 1 phase will lower the power even more. I doubt you will be able to drill anything at all. My advice is to pick up a 230V, single phase variable frequency drive (VFD). They come very cheap on ebay, especially for such alow power. And you will have the benifit of continuously variable speed control. You probably have a 230/400V motor. a 230V single phase input VFD will give you approximately 3x220V output. So you need to put the motor in delta when using such a drive.
Kind greetings,
Pascal.
