Dear all,
My LG flatron 21" CRT television is only showing menu(OSD) on the screen as showing in an attached picture. All ABL side components are ok. Tuner 5 V and 33 V are ok. Two transistors around jungle IC are ok. CVBS pin of the jungle IC has signal like a noise. Is it normal? Few days ago, I have replaced the flyback and HOUT after 7 years. This was sitting about 7 years in a room. Can I solve this?
Thanks.
